Make beep optional in ring groups
Discussion in 'Ideas' started by cobaltit, Apr 5, 2018.
Make beep optional in ring groups 5 5 1votes
5/5, 1 vote
  1. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    918
    146
    So with the ability to add multicast ring groups via the provisioning page we are one step closer to removing a common need for custom templates. However a lot of our installs for stores and such included overhead paging as part of the ring group and most clients don't want that beep going out over the overhead paging. If we could make the beep a check box in the paging group that would be great.
    #1 cobaltit, Apr 5, 2018
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,311
    249
    I'm confused a bit.
    Don't want what? We have Speakers as part of Multicast Paging Groups... Nothing beeps. Are you wanting to add a beep? The speaker I'll admit is manually setup as it is not an extension. It is just a Paging Endpoint.
  3. cobaltit
    Mar 22, 2012
    918
    146
    Sorry that was poorly worded. Basically 3CX sends a beep out when you configure a paging group. Most people don't care when it is just phones as part of the paging group but when you put in a paging adapter such as a Cyberdata then you get the beep going out over the overhead paging.
  4. craigreilly
    Feb 1, 2012
    3,311
    249
    hmm. no beeps on mine.
