Solved make call doesn´t work
Discussion in '3CX Clients' started by Jan Koberg, Nov 12, 2017.
Tags:
  1. Jan Koberg
    Oct 18, 2017
    7
    I have the version 15.5.5 (Windows) and a Gigaset Pro as Dect basis.
    The description says that only makecall works. I'm aware of that. Only I have the problem that I do not even when dialing with the Windows client in CTI mode get the make call call.
    Is there a way to trace something? Calls are displayed in the Windows client. Everything else works wonderfully.
    I would be grateful for any idea. greetings Jan
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    Hello @Jan Koberg
    Which GIgaset dect are you using? Is the device local and auto provisioned using the default template? Also what firmware is the dect running?
  3. Jan Koberg
    Oct 18, 2017
    7
    Hi, N720 Pro DECT Manager with 6 basestations N720 Pro firmware is 108. Provisioned using the default template and local.
  4. poynter.net
    Aug 26, 2009
    36
    5
    Also have this issue, since installing the beta of sp2 the CTI client does nothing when you press the call button.
  5. YiannisH_3CX
    May 10, 2016
    7,783
    563
    Can you upgrade to SP2 final and let me know if you still face the issue? Make sure that the phones and clients are updated to the recommended version for SP2.
  6. poynter.net
    Aug 26, 2009
    36
    5
    Yes, SP2 already installed and same issue. Resolved by re-provisioning the phones.
  7. YiannisH_3CX
    May 10, 2016
    7,783
    563
    Glad to hear the issue is resolved
  8. Jan Koberg
    Oct 18, 2017
    7
    I´ve upgraded to SP2 still the same problem. How is the makecall feature flow, does it use a special port? There is no error message, this is confusing me.
  9. YiannisH_3CX
    May 10, 2016
    7,783
    563
    Do you see presence on the client? Can the windows client and the Dect phone make and receive calls when not in CTI mode?
    The initial communication from the client to the PBX is through presence, then the PBX initiates a call to the phone. When the "Make Call" is answered the PBX will also call the called number and connect the 2. So if presence and calls are working then Make Call should also be working
  10. Jan Koberg
    Oct 18, 2017
    7
    Yes presence is working, calling and receiving call from softphone also. :( Is there a trace option? I don´t see anything related in Wireshark. On my private 3CX its works, but also tried to Trace with Wireshark. I don´t see the related packets since it uses https i guess.
  11. YiannisH_3CX
    May 10, 2016
    7,783
    563
    Yes unfortunately the communication is https and not visible in wireshark. From the pc where the client is, can you access the DECTs base web interface? Can you try a different device and see if that works?
  12. Jan Koberg
    Oct 18, 2017
    7
    Yes the web interface is reachable from the client.
    Also tried successfully a sip client (zoiper) which can call the DECT Handset.
    Make call does also work, if i switch the cti client to the sip softphone(zoiper). In call log (Management Interface) there are listings IVR (MakeCall) to the Dect Handset.
  13. Jan Koberg
    Oct 18, 2017
    7
    Next step was resetting the Dect Manager to Factory Defaults but this also did not bring the make call feature back. :( It seems that the call manager can't call the Dect in make call. All other calls from the PBX are just fine. Recording or playback of files are working.
  14. YiannisH_3CX
    May 10, 2016
    7,783
    563
    Please check your inbox as i have sent you p.m. with some files i need to further troubleshoot your issue.
  15. Jan Koberg
    Oct 18, 2017
    7
    Yes now i am Successful. The problem is, that the logs don't point to the problem.
    After reinstalling the PBX, the problem is still there.
    The solution is to disable German: Gegensprechen !
    I think the translation is a bit more meaningful in english.
    [​IMG] [​IMG]
    I don't know what it does. Eventually a special header that causes the Gigaset to reject the Make Call feature.
    Best Regards Jan
    Tsialdartzis Kostas likes this.
  16. YiannisH_3CX
    May 10, 2016
    7,783
    563
    Glad to hear the issue has been resolved and thank you for sharing your solution
    Jan Koberg likes this.
