Make Call - Outlook Dialer
Discussion in '3CX Phone System - General' started by badsushi, Feb 16, 2012.
  1. badsushi
    Mar 26, 2011
    27
    I have been trying to use more features of the 3CX and have been using the outlook dialer a couple real annoying things -
    1) When dialing from contacts it generates a "Make Call" which generates a call to my phone - (even with user intercom when dialing option checked in myphone) So I get a screen pop from my own extension calling my own extension -
    2) Even worse I use the ring my mobile simultaneously option all the time - so every time I generate a call via the contacts I get a screen pop and it generates a call to my cell phone - wish there was a delay timer here for when I'm in the office.
    3) I would love to hear ring back instead of Music on hold during the "make call process"
    I was going to submit a few ideas to the ideas page but wanted to see if any of this could be fixed with programming.
    I was wondering if anybody has a work around for these problems I'm experiencing.
    Thanks in advance, -Jake
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    2) I'd simply go into extensions--->forwarding rules--->from there you can customeize settings to ring desk phone first than cell phone after X seconds.
  3. sossie07
    Oct 25, 2011
    Hi all
    I agree with badsushi, its annoying that using the outlook click to dial:
    a; first rings the phone and which I have to answer,
    b; then it puts me on hold while making the call
    I can live with "a" ringing my deskphone, but "b" where is puts me on hold is very annoying as I always miss the first second of the call once its established.
    I have had a look but couldn't find anything. Is there anyway to alter these settings?
    cheers, Simon.
  4. sossie07
    Oct 25, 2011
    Hi all
    cheers, Simon.
  5. jpillow
    Jun 20, 2011
    1,342
    I'm not sure how it is you always miss one second of a call I never have that issue maybe there is some setting that needs to be tweeked. What that is if any I'm not sure if I were you I'd post and see what responses you get.
