if i use automatic configuration (4554 instead 4552)
there are many errors -
the log:
System type is SN4552/2BIS/EUI, 0002-0001
Serial No. 00A0BA03409C
Proceed with standard boot.
Checking PLDs...
Planar board : checking - please wait (this may take some seconds)
PLD OK, Version = 0x45010106
Installing Drivers...
Ethernet 0/0 MAC Addr 00:A0:BA:03:40:9C, RxQ 32, TxQ 64
Ethernet 0/1 MAC Addr 00:A0:BA:03:40:9D, RxQ 32, TxQ 64
Starting Modules...
1970-01-01T00:00:01 : Target Shell
All modules successfully started
Config startup-config READ [ OK ]
Config startup-config EXECUTE 1970-01-01T00:00:10 : LOGINFO : Link down on interface ethernet 0 0 0
1970-01-01T00:00:16 : LOGWARNING : Errors in configuration of router 'switch' ('show call-router switch reload' for details)
[FAILED]
1970-01-01T00:00:23 : LOGWARNING : Previous message repeated 2 times
1970-01-01T00:00:23 : LOGWARNING : Config: Line 6: SN4552/2BIS/EUI(ic-voice)[0]#low-bitrate-codec g729
1970-01-01T00:00:23 : LOGWARNING : Config: % ^ Keyword mismatch
1970-01-01T00:00:23 : LOGWARNING : Config: Line 9: SN4552/2BIS/EUI(sys)#clock-source 0 0
1970-01-01T00:00:23 : LOGWARNING : Config: Line 57: SN4552/2BIS/EUI(pf-pstn)[default]#profile sip default
1970-01-01T00:00:23 : LOGWARNING : Config: Line 80: SN4552/2BIS/EUI(if-isdn)[isdnif1]#interface sip sipif0
1970-01-01T00:00:23 : LOGWARNING : Config: Line 81: SN4552/2BIS/EUI(if-isdn)[isdnif1]#bind gateway sipgw0
1970-01-01T00:00:23 : LOGWARNING : Config: Line 82: SN4552/2BIS/EUI(if-isdn)[isdnif1]#service default
1970-01-01T00:00:23 : LOGWARNING : Config: Line 84: SN4552/2BIS/EUI(if-isdn)[isdnif1]#remote-party-id called-party
1970-01-01T00:00:24 : LOGWARNING : Config: Line 85: SN4552/2BIS/EUI(if-isdn)[isdnif1]#address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
1970-01-01T00:00:24 : LOGWARNING : Config: % ^ Keyword mismatch
1970-01-01T00:00:24 : LOGWARNING : Config: Line 86: SN4552/2BIS/EUI(if-isdn)[isdnif1]#address-translation incoming-call called-e164 request-uri
1970-01-01T00:00:24 : LOGWARNING : Config: Line 88: SN4552/2BIS/EUI(if-isdn)[isdnif1]#interface sip sipif1
1970-01-01T00:00:24 : LOGWARNING : Config: Line 89: SN4552/2BIS/EUI(if-isdn)[isdnif1]#bind gateway sipgw1
1970-01-01T00:00:25 : LOGWARNING : Config: % ^ Keyword mismatch
1970-01-01T00:00:25 : LOGWARNING : Config: Line 90: SN4552/2BIS/EUI(if-isdn)[isdnif1]#service default
1970-01-01T00:00:25 : LOGWARNING : Config: Line 92: SN4552/2BIS/EUI(if-isdn)[isdnif1]#remote-party-id called-party
1970-01-01T00:00:25 : LOGWARNING : Config: Line 93: SN4552/2BIS/EUI(if-isdn)[isdnif1]#address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
1970-01-01T00:00:25 : LOGWARNING : Config: Line 94: SN4552/2BIS/EUI(if-isdn)[isdnif1]#address-translation incoming-call called-e164 request-uri
1970-01-01T00:00:25 : LOGWARNING : Config: Line 99: SN4552/2BIS/EUI(ctx-cs)[switch]#gateway sip sipgw0
1970-01-01T00:00:25 : LOGWARNING : Config: Line 100: SN4552/2BIS/EUI(ctx-cs)[switch]#bind interface eth0 router
1970-01-01T00:00:27 : LOGWARNING : Config: % ^ Keyword mismatch
1970-01-01T00:00:27 : LOGWARNING : Config: Line 102: SN4552/2BIS/EUI(ctx-cs)[switch]#service default
1970-01-01T00:00:27 : LOGWARNING : Config: Line 103: SN4552/2BIS/EUI(ctx-cs)[switch]#domain 192.168.0.170
1970-01-01T00:00:27 : LOGWARNING : Config: Line 104: SN4552/2BIS/EUI(ctx-cs)[switch]#authentication 10000 password 10000 default
1970-01-01T00:00:27 : LOGWARNING : Config: Line 105: SN4552/2BIS/EUI(ctx-cs)[switch]#default-server 192.168.0.170 loose-router
1970-01-01T00:00:27 : LOGWARNING : Config: Line 106: SN4552/2BIS/EUI(ctx-cs)[switch]#registrar 192.168.0.170
1970-01-01T00:00:28 : LOGWARNING : Config: Line 107: SN4552/2BIS/EUI(ctx-cs)[switch]#user 10000
1970-01-01T00:00:28 : LOGWARNING : Config: % ^ Keyword mismatch
1970-01-01T00:00:28 : LOGWARNING : Config: Line 109: SN4552/2BIS/EUI(ctx-cs)[switch]#gateway sip sipgw0
1970-01-01T00:00:28 : LOGWARNING : Config: Line 112: SN4552/2BIS/EUI(ctx-cs)[switch]#gateway sip sipgw1
1970-01-01T00:00:29 : LOGWARNING : Config: % ^ Keyword mismatch
1970-01-01T00:00:29 : LOGWARNING : Config: Line 113: SN4552/2BIS/EUI(ctx-cs)[switch]#bind interface eth0 router
1970-01-01T00:00:29 : LOGWARNING : Config: Line 115: SN4552/2BIS/EUI(ctx-cs)[switch]#service default
1970-01-01T00:00:29 : LOGWARNING : Config: Line 116: SN4552/2BIS/EUI(ctx-cs)[switch]#domain 192.168.0.170
1970-01-01T00:00:30 : LOGWARNING : Config: Line 117: SN4552/2BIS/EUI(ctx-cs)[switch]#authentication 10001 password 10001 default
1970-01-01T00:00:30 : LOGWARNING : Config: % ^ Keyword mismatch
1970-01-01T00:00:31 : LOGWARNING : Config: Line 118: SN4552/2BIS/EUI(ctx-cs)[switch]#default-server 192.168.0.170 loose-router
1970-01-01T00:00:31 : LOGWARNING : Config: % ^ Keyword mismatch
1970-01-01T00:00:31 : LOGWARNING : Config: Line 119: SN4552/2BIS/EUI(ctx-cs)[switch]#registrar 192.168.0.170
1970-01-01T00:00:31 : LOGWARNING : Config: Line 120: SN4552/2BIS/EUI(ctx-cs)[switch]#user 10001
1970-01-01T00:00:31 : LOGWARNING : Config: Line 122: SN4552/2BIS/EUI(ctx-cs)[switch]#gateway sip sipgw1
1970-01-01T00:00:31 : LOGWARNING : Config: Line 126: SN4552/2BIS/EUI(prt-eth)[0/0]#medium auto
1970-01-01T00:00:32 : LOGWARNING : Config: % ^ Keyword mismatch
1970-01-01T00:00:32 : LOGWARNING : Config: Line 160: SN4552/2BIS/EUI(q931)[0/1]#uni-side user
1970-01-01T00:00:32 : LOGWARNING : Config: % Clock mode slave is not supported
Opening Modules...
All modules successfully opened
System is up.
1970-01-01T00:00:33 : LOGINFO : Link up on interface ethernet 0 0 0
1970-01-01T00:00:33 : LOGINFO : Link up on interface eth0
1970-01-01T00:00:34 : LOGINFO : Warm start.
