Make Queue behave like Ring Group?
Discussion in '3CX Phone System - General' started by dig1234, Aug 17, 2015.
  1. dig1234
    Jun 1, 2015
    75
    Is there a way to get a queue to ring all extensions even if they are busy ? Currently if a queue member is on the phone and a queue call comes in it will only ring the free extensions. I understand this makes sense in a call center setting but in a small office what if someone is on a personal call and wants hang up as soon as a more important call comes in...
    I recently switched from ring group to queue in order to utilize the login/logout feature. With the ring group I was able to configure the ALLOWUSEBUSYOPTFORGROUP setting but this doesn't seem to affect the queue. Is there a workaround to get the best of both worlds: the login/logout feature of the queue and the forced ringing even if busy of the ring group? Or is that too much to ask ;)
    10,368
    229
    The whole idea of a queue is that you expect more calls than you will have agents, so it provides a way to hold the caller, then sent the call to the first idle agent. It is expected that the idle agents are going to be able to focus on the caller. Changing how a queue operates, might be a bit much to ask for.
    If this happens on a regular basis, I would create a second extension key on each set. Put those extensions in the Ring Group, they could be made to block any outgoing calls so that they would be available only for incoming . If the person was using their main extension number and wished to take a ring group call, they could.
