Make voip call from Android/IOS application through 3cx
Discussion in 'Ideas' started by bosiogerman, Apr 6, 2018.
Make voip call from Android/IOS application through 3cx 5 5 1votes
5/5, 1 vote
  1. bosiogerman
    Mar 20, 2017
    5
    Hi,It would be great if the 3cx client on mobile device could be opened from an android/ios application, indicating the origin (extension) and the destination of the call, either directly calling the client installed on the device or a pbx api to make a call using 3cx instead traditional phone call.
    It is usefull when a crm application run on mobile device and need to make voip call
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    Guessing that iOS won't allow this. Not sure about Android.
    #2 craigreilly, Apr 6, 2018
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    For iOS client, you can do this, because it implements handling of our custom protocol, tcxcallto.
    Therefore, from any iOS application you made, all you have to do is to open something like
    tcxcallto://123456
    You may try quickly this in Notes.
    Hope it helps
    vali
    craigreilly likes this.
  4. craigreilly
    Feb 1, 2012
    3,551
    298
    I misread. I was thinking he wanted 3cx server to initiate a call and use iOS/Android App as the client.
  5. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Np - either way, even this tcxcallto doesn't fully cover @bosiogerman request
