make_call.php
Discussion in '3CX Phone System - General' started by bartus, Apr 1, 2008.
  1. bartus
    Apr 1, 2008
    Is this function available/working in the free edition?
    I cannot make it work..
    Thanks,
  2. cevatkerim
    Jan 20, 2008
    14
    same here. no output... nothing..
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    No, it is disabled in free edition.
  4. etsik
    Apr 16, 2008
    13
    But i do NOT use the free edition!!!
  5. archie
    3CX Support
    Aug 18, 2006
    1,299
    Original question was about free edition. If you use paid edition - it should work. It has been tested many times in different environments and it is working.
  6. coelhopsi
    May 7, 2008
    84
    What is this make_call.php file about? I couldn't find any references to it from other files...
  7. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Make_call is the ability to make calls using Http. Also known as HTTP API.
    You can make a call from your browser using HTTP post request.
    Example:
    open browser and type:
    http://localhost:5481/make_call.php?extnum=222&vmpin=222&to=XXX
    Localhost – is the IP or name of the 3CX Phone System server.
    extnum – is the extension number of the user placing the call. HTTP post request will authenticate using 222 (vmpin num of extension 222). Ext 222 will ring. You will then hear "Please wait while I forward your call"
    Call will be forwarded to Destination XXX which can be an extension or Outbound rule and external location.
    You can notice that make_call uses extnum and vmpin. Do not try and use extnum and auth password you set in the extension. Maybe this is why it's not working for you etsik.
  8. coelhopsi
    May 7, 2008
    84
    Hummmm... interesting! Is it needed to authenticate as admin before using this PHP? Or any user can type it in his browser?
  9. Halea
    Halea New Member
    Jan 5, 2008
    151
    Indeed you need to have the voice mail function turned on for the extension that will be the caller, and you need to use the pin number for that voice mail box when you invoke the make_call.php page.
    Halea
  10. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Any user can type it. No need for admin rights.
    -- Yes If VM function is not on, then voicemail pin is not part of the function and cannot be called for authentication. In fact it will be greyed out in the interface.
    Good it's working for you.
  11. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    Sorry to jump in here
    Just to be clear - users can only trigger calls via this interface for their own extension. To do this, it requires an extension number as well as the extension pin. No admin rights are required, though as a user the only thing you can do is setup a call to your own extension.
