MakeCall - Music on Hold played Yealink T28 Mute
Discussion in '3CX Phone System - General' started by garethb_83, Oct 12, 2010.
  1. garethb_83
    Oct 11, 2007
    25
    Is there a way we can make a call using the 3CX assistant / Hardphone using the make call feature but instantly connect the call so you can hear the call progress tone(s) ? My Clients would rather hear the ringing tone rather than music on hold.. (Think its more of a comfort issue)
    Probably need to aviod creating a WAV with the ringing sound!!
    Also, when used with Yealink T28 and use intercom method, can we disable/enable the mute feature? I know I can disable the intercom method via 3CX assistant but would rather keep it on and not mute the phone when calling.
    Kind Regards
    Gareth
  2. danoh
    Aug 18, 2010
    56
    I would like this also. It's really odd to use MakeCall and to hear our own onhold music then all the sudden the called party responds with "Hello?"
    We'd rather hear the call progress tones, like ringing, busy signal, etc.
  3. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    I don't think there is an option at the moment. Suggest ring tone with call assistant calls at http://3cx.ideascale.com/
    Richard Crabb
  4. daveharbon
    May 9, 2012
    Is there a solution to this problem yet? I would also like ot be able to hear a ring tone. It's also a bit off putting when you need to press mute to start speaking?
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,969
    182
    With Yealink - why not just make the call on the handset using the phones interface:
    http://user:22222@phoneip/cgi-bin/cgiServer.exx?number=%number%
    This setting is in the "GEAR" (edit) under Preferences of MyPhone.
