Making an extension ring that is not tied to a phone
Discussion in '3CX Phone System - General' started by BradKopecky, May 4, 2017.
  1. BradKopecky
    Jun 7, 2016
    5
    We want to setup some internal extensions that are used for notifying our staff of a new client. Long story but in our profession sound is an issue so we wanted something that simply changed the light of a monitored extension. We are using Yealink T42G phones.
    Our plan had been to use a BLF to the assigned notification extension to show the status of that line. The front desk would call the notification extension and the staff members phone would show activity on the monitored extension. Simple notification, no sound. We would set the activity status to ring for 5 minutes before going back to the front. However, since the notification extensions are not tied to a phone or 3cx client, they cannot "ring" and the call goes directly to voicemail.
    Is there any way to make these extensions work in the way I described even though they are not assigned to a phone or a softphone client?
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Not sure I understand exactly what you are doing but you can assign more than one extension to a phone. You can't do this through the regular provisioning but you can edit the phone's configuration through the phone web interface. Not sure if that helps?
    Would it work to just ring the primary extension on the phone and turn the volume of the ringer off?
    Allen
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
    As i understand it you want the extensions registered so they ring and the BLF keys for these extensions light up in the phones that monitor these extensions.
    There are a couple of ways to register an extension without a phone. The first is register the extension with a mobile device (Android or IOS) and make sure push in enabled under extension settings phone provisioning.
    The other way is populate the mobile Number field of the extension with a number and enable the option ring my phone simultaneously under the forwarding rules of the extension. This will keep the extension registered and the BLF status will update when a call comes in
  4. BradKopecky
    Jun 7, 2016
    5
    That last one sounds closer to what we are looking for. Odd question but since I actually don't want a device to ring anywhere, does the external number have to be a valid number?
  5. YiannisH_3CX
    May 10, 2016
    7,301
    530
    No it can be a random number that does not ring anything. Both ways will keep the extension registered so you can achieve what you want
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    Could you perhaps just buy a cheap IP phone or an ATA and put it in the server room or something?
  7. BradKopecky
    Jun 7, 2016
    5
    The random number worked perfectly.
    We have about fifty staff to do this for so the extra phone would not be an ideal solution.
