Making call to SIP Call-ID on Android client
Discussion in 'Android' started by boardshorts, Mar 1, 2011.
  1. boardshorts
    Mar 1, 2011
    The Windows client allows you to call a SIP Call-ID (eg 123456@sip.domain.com) when you configure the SIP Call-ID in the phone number field in the phonebook. Android version 1.2.9 converts the alpha numeric SIP Call-ID to just numbers, if you select that contact's SIP Call-ID from the contact list. The call then fails. If you manually enter the SIP Call-ID in Android no conversion happens but the call also fails.
    Both the Windows and Android clients are running using WI-FI behind the same NAT router and both use STUN to sucessfully dial and receive calls to/from mobile, fixed line and DID numbers, it is just the SIP Call-ID processing that is missing from the Android version.
    Is this likely to be fixed in the next version? Need to make a decision on both the Windows and Android clients that we roll out.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    This is not a bug, it's a feature request and unfortunately this is something we are not planning on implementing in the next version of the 3CXPhone for Android.
