- Joined
- Aug 29, 2008
- Messages
- 1
- Reaction score
- 0
Hi everyone...
We are toying with an idea of replacing our aging propriotary PBX with 3CX. My current test envoroment is:
3CX version 6
2 - Linksys SPA921
1 - Linksys SPA3102
I'm able to make calls from extension to extension, that works great
I connected SPA3102 to POTS line to make outgoing calls
my config looks like this
3CX server 192.168.6.8
SPA921-1 192.168.6.9
SPA921-2 192.168.6.10
SPA3102 192.168.6.12 (wan port) (lan port is default)
I have an outbound rule in place
RULE NAME: PSTN1
APPLY TO EXTENSIONS: 100-110
ROUTE 1 - PSTN1
When I look into Server status i see he following entries:
[CM503003]: Call(5): Call to sip:[email protected]:5060 has failed; Cause: 404 Not Found; from IP:192.168.6.12:5060
[CM503015]: Call(5): Attempt to reach [sip:[email protected]] failed. Reason: Not Found
[CM503008]: Call(5): Call is terminated
(5555555555 -< is the numner i'm trying to dial)
Line status says:
PSTN Lines
10000 Line No: 10000
Status: Registered (idle
Any help is greatly appriciated
Alex
3CX version 6
2 - Linksys SPA921
1 - Linksys SPA3102
RULE NAME: PSTN1
ROUTE 1 - PSTN1
Line status says:
PSTN Lines
Alex
