Making external calls using Sipgate
Discussion in '3CX Phone System - General' started by tsymonds, Aug 17, 2007.
  1. tsymonds
    Aug 17, 2007
    6
    In order to determine if I have a problem with 3CX, I have a question:
    Using the free version is it possible to make external calls using a VOIP provider like Sipgate.
    Many Thanks
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Yes. There is no problem. SIPGATE works just fine with free version
  3. tsymonds
    Aug 17, 2007
    6
    Ok, Thanks.
    I have a problem then:
    I can receive calls from Sipgate with no problem, however I can not make any external calls even using the Sipgate test 10000 number.
    These are the messages from the Server Status
    14:59:43.419 CallConf::eek:nIncoming [CM003002] Call(1): Destination not available for call from sip:100@172.16.20.2 to sip:10000@172.16.20.2
    14:59:43.419 CallConf::Rejected [CM103005] Call(1) is rejected: Destination does not exist, or is not registered
    14:59:42.622 CallConf::eek:nIncoming [CM103002] Call(1): Incoming call from 100 (Ext.100) to sip:10000@172.16.20.2
  4. rapidtechltd
    Aug 13, 2007
    sipgate
    have you got an outbound rule set
  5. tsymonds
    Aug 17, 2007
    6
    I have fixed the problem over the weekend:
    You are correct it is to do with rules, I deleted th r from the Transform mask field and this fixed the problem.
    Thanks for all your help.
