Mamut
Discussion in '3CX Phone System - General' started by davidbenwell, Mar 24, 2011.
  1. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Has anyone been able to get 3CX to bring up a customer record within Mamut
    need a solution whereby customer rings and then it brings up that customer details witnin Mamut.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Im unsure what mammoth is, but i inmagine it is a client database of some sort, the 3cx assistant allows you to send the number to a particular appilcation, maybe this is the way you may wish to go.
