Manage outbound call rules - Dial Plan
Discussion in '3CX Phone System - General' started by ilkeryildiz, Jan 8, 2007.
  1. ilkeryildiz
    Jan 7, 2007
    26
    my suggestion:
    * You must add " Register Now" button on "Line Status" or "Line Manage
  2. fischershaw
    Jan 3, 2007
    16
    FreeSwitch has a more interesting approach, with a lot of customization of rules, and full regular expression parsing. Admittedly it is just a YAULP (Yet Another Undocumented Linux Project), but that part works well. In any case, handling regular expressions would be a much more useful approach.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,005
    308
    HI,
    Thank you for your feedback.
    The outbound call rules interface has been improved in the next beta although a prefix to dial outside numbers will always be required as on any PBX (unless it has a proprietary phone)
    We have tried to keep the outbound rules interface simple, since we feel this will serve most customers best. Of course we are open to feedback about this.
  4. fischershaw
    Jan 3, 2007
    16
    Yes, I would agree with the keep-it-simple plan to cover the most common cases, as long as there is some "advanced" button to allow one to describe a more detailed expression.
  5. ilkeryildiz
    Jan 7, 2007
    26
    VoIP Outbound Rule suggestion:
    I can choice voip provider but i can't choice "line" under provider.
    I have two account at one provider. I want create rule some extensions a account and other extensions another account.
    You must add line choice at menu.
