Management console and Chrome browser
Discussion in '3CX Phone System - General' started by KerryG, May 28, 2010.
  1. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Backed up v8 system
    Uninstalled v8 System
    Installed v9 w/Abyss
    Restored v8
    Web interface just shows "loading" animation, have to do all maintenance with the management console.
  2. KerryG
    Jun 19, 2009
    960
    Re: NEW 3CX Phone System Version 9 Beta Released
    After more testing. I discovered that the web interface is only not working with Chrome. It does seem to work with IE8 and FF.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Clear chrome cache.
    Clear ff and ie cache too.
    3CX Web interface definitely works with Chrome. What does not show correctly are the grids like in the custom parameters for example or lists.
    Therefore you should not use Chrome to manage 3CX.
