Solved Management Console - Login Problem
Discussion in '3CX Phone System - General' started by Matthew Lidbetter, Feb 5, 2018.
  1. Matthew Lidbetter
    Jan 26, 2018
    13
    I have an issue logging into the management console.
    I don't believe I have changed user name or password as (I use a password vault)
    I am getting the message
    Login access denied. Too many incorrect login attempts. Try later or contact the Administrator.
    Any thoughts ?
  2. simply7
    Jan 4, 2016
    38
    18
    You blacklisted yourself.
  3. Matthew Lidbetter
    Jan 26, 2018
    13
    OK - so if i've blacklisted myself - is there any way to get back in ?
  4. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    112
    19
    Blacklisting is usually by IP address, and for 30 minutes... unless manually entered. If you are still locked out, can you log in from another computer (different IP address)?
  5. Matthew Lidbetter
    Jan 26, 2018
    13
    I have tried waiting for an hour as well as logging in from another computer (ipad) but I'm still locked out.
    I have checked my username and password and they are correct (the ones issued by 3CX), but, no joy.
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Is the PBX local or remote? If remote you will need to try from a different public IP address. Also please note that in SP2 the blacklist time interval has been increased to 86400 seconds (24 hours).
  7. Matthew Lidbetter
    Jan 26, 2018
    13
    Thank you - it is remote and I have only been waiting about 8 hours.
    I will try again from a different public IP
  8. YiannisH_3CX
    May 10, 2016
    6,016
    420
    You can try from your phone with 3G/4G if you have a mobile plan. Let us know of the results
    Matthew Lidbetter likes this.
  9. Matthew Lidbetter
    Jan 26, 2018
    13
    FANTASTIC
    I logged on through my cell phone and enabled the blacklisted IP address
  10. YiannisH_3CX
    May 10, 2016
    6,016
    420
    Glad to see the issue has been resolved. You can whitelist your public ip to prevent this from happening again
