Management Console not working?
Discussion in '3CX Phone System - General' started by discoverit, Oct 28, 2009.
  1. discoverit
    Oct 28, 2009
    Hello all,
    i am pretty new to the 3cx program, but I am loving it so far.
    The problem that I have is that I am unable to get into the management console any more. I have recently upgrade my computer to Windows 7 and the 3cx software is installed on SBS 2008 and is working great.
    I have version 7.1 installed on IIS and have spent a number of hours reading the post's already and could not find any thing that helps me out.
    When I put in the address for the management site all I get is the little blue symbol in the top right corner, which to me says that it finds the page alright but am unable to see any thing in the screen.
    I was also looking at maybe upgrading to version 8 to fix this problem but need to look in to how to save the config if the management console does not load?
    Any help or pointers would be great.
    Rob
