Management Console Timeout
Discussion in '3CX Phone System - General' started by rnoguera, Nov 13, 2007.
  1. rnoguera
    Oct 25, 2007
    89
    When you login to the Administration Console, and you stop your activity for some time, the session times out after several minutes.
    If you wish to resume your work you have to login again.
    Do you know how to change the timeout time?
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hi.
    Never had that problem.
    Try to keep the console at page "Line Status".
    The page refreshes often and so keeps the console active. Timeout should be prevented.
  3. etelecom
    Apr 6, 2009
    8
    Re:
    Did that, but still it was logged out.
    Help needed.(If available)
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    The Value is in Minutes so feel free to Edit it to your liking.
  5. LeonidasG
    Nov 19, 2008
    1,399
    79
    Ah sorry forgot to Mention the paths Vary on Different Operating Systems and 3CX Versions.
    For Version 6 you will find this in
    C:\ProgramFiles\3CXPhoneSystem\3CX\Data\Http\Interface\web.config
    For V7.1 on XP
    C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\web.config
    For 7.1 on Vista / 2008 Systems
    C:\ProgramData\3CX\Data\Http\Interface\web.config
    I hope this Helps.
  6. LeonidasG
    Nov 19, 2008
    1,399
    79
    Are you trying to ADD the code i gave you into the config file?
    Of course that's gonna cause problems :p
    What i ment is that in the web.config file there will be a line <add key="MainPageTimeout" value="10">
    Just change the 10 to something bigger. 10 is the value in minutes, 10 minutes.
    I hope this clears things up.
  7. Scientio
    Mar 24, 2007
    8
    It would be good to find out how to retrieve the Username and password.
    Twice now I've installed the system, set up usernames etc, and found later that the Management console won't recognise them.
    Andy
