Management Console won't load
Discussion in '3CX Phone System - General' started by patricksmalley, Jul 21, 2016.
  1. patricksmalley
    May 13, 2016
    12
    Help, I can't get NGinx to load the management portal.
    Checking for open ports using:
    netstat -a |more
    I don't see it listening on 5000 or 5001.
    I tried every option I could think of in the post-installation configuration tool to try and get things to load, no success.
    I tried checking error.log here:
    C:\Program Files\3CX Phone System\Bin\nginx\logs
    As well as any other log I could find, nothing (including system/application event log).
    Why did they have to change the installation process and web engine?!?
    Downgrading back to v14 so I can have a running PBX.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    If I may ask next time please do the following,
    Start CMD cd location C:\Program Files\3CX Phone System\Bin\nginx
    Type nginx_svc.exe -h
    If you see help commands, then type nginx_svc.exe start
    Tell us what you see.
  3. teldata1
    Aug 24, 2015
    63
    Having the same issue on our system as well.
  4. patricksmalley
    May 13, 2016
    12
    Ok, got mine working. Here are the things I changed:
    1. In the backup.zip I entered the new v15 key (within the xml config file) and re-packed the zip. Why didn't the configuration tool stop the process and give me a chance to fix the problem instead of uninstall/reinstall.
    2. My certificate key file was encrypted so I converted it to a decrypted key. Not sure why the configuration utility didn't catch this.
    With both of these changes things are working great now. Loving the new interface.
