management portal
Discussion in '3CX Phone System - General' started by Heath, Mar 30, 2018.
  1. Heath
    Heath New Member
    Aug 12, 2017
    122
    I cant get logged in to the management portal... I keep getting server error
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,577
    209
    Hi Heath,
    That's not a password issue.
    I have seen this before when either doing an update or restarting the services and not giving them time to fully reload.
    First place to check is the 3CX services on the server itself I think there is a high chance some are not running.
