Manager Log In/Out
Discussion in '3CX Phone System - General' started by GManNAtl, Sep 14, 2012.
  1. GManNAtl
    Sep 13, 2012
    58
    Can someone using Call Center confirm this for me . . . .
    As a Que Manager you can not log in/out an agent while on the Que tab. You have to go back to the extensions tab to perform this function? Our installation is only about 65 phones, but finding the agent on the extensions tab is cumbersome at best, especially since agents in the que might not directly relate to an extension group on the other tab.
    If this is indeed the way it works for others I have posted this to the FB Feature request. This seems like a no brainer to be voted up for CC users.
  2. GManNAtl
    Sep 13, 2012
    58
    Nevermind :)
    I guess this was added in v11 SP1? I didn't catch it in the release notes, but glad it's there!
