Manging Ext 999 - Voice Mail
Discussion in '3CX Phone System - General' started by abruton, Jan 14, 2009.
  1. abruton
    Dec 8, 2008
    7
    I'm battling to get Voice Mail (VM) to work. There is no extension 999 listed under the extensions. The rest of the system is running well.
    When I phone an extension, I do not get through to the VM system. Here is the logs:
    11:00:05.068 Call::Terminate [CM503008]: Call(63): Call is terminated
    10:59:40.099 CallCtrl::eek:nLegConnected [CM503007]: Call(63): Device joined: sip:999@127.0.0.1:40600;rinstance=e527a84568740144
    10:59:40.099 CallCtrl::eek:nLegConnected [CM503007]: Call(63): Device joined: sip:208@192.168.0.208:5060;transport=udp;user=phone
    10:59:40.099 Extension::printEndpointInfo [CM505001]: Ext.999: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX MakeCall helper] Transport: [sip:127.0.0.1:5060]
    10:59:40.099 CallCtrl::eek:nAnsweredCall [CM503002]: Call(63): Alerting sip:999@127.0.0.1:40600;rinstance=e527a84568740144
    10:59:39.568 CallCtrl::eek:nRerouteReq [CM503005]: Call(63): Forwarding: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=e527a84568740144]
    10:59:39.552 Call::RouteFailed [CM503015]: Call(63): Attempt to reach [sip:679@192.168.0.150;user=phone] failed. Reason: Not Registered
    10:59:39.552 CallCtrl::eek:nSelectRouteReq [CM503016]: Call(63): Target is not registered: Ext:Ext.679
    10:59:39.552 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:679@192.168.0.150;user=phone]
    10:59:39.552 Extension::printEndpointInfo [CM505001]: Ext.208: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream BT200 1.1.6.44] Transport: [sip:192.168.0.150:5060]
    10:59:39.552 CallCtrl::eek:nIncomingCall [CM503001]: Call(63): Incoming call from Ext.208 to [sip:679@192.168.0.150;user=phone]
    I've checked the settings and all extensions have VM activated.
    Any ideas how to manage the VM extension?
    Best regards
    Andre
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    The VM extension 999 will not appear in the Extension list as it is not a physical extension.
    What exactly would you like to do OR what exactly is the issue you are encountering. VM is responding to calls.
  3. abruton
    Dec 8, 2008
    7
    There is no VM prompt or anything, just silence. Everything is switched on for VM (I think).
    Best regards
    Andre
  4. William400
    Aug 21, 2006
    1,005
    What OS and SP level are you running? What version and build of 3CX are you running?
    Can you enable Verbose mode and paste the Server Status logging for a call to 999 ? Please ensure you make the call to 999 from a 3CX VOIP Client in headset mode.
