Manual Registration
Discussion in '3CX Phone System - General' started by claxtro, Feb 9, 2012.
  1. claxtro
    Mar 12, 2011
    22
    Hi-
    We are having difficulty having a nonsupported endpoint register with our 3cx system because of 407 authentication errors. Anyone know of a way of manually registering an extension in 3cx (points to the IP address and port of extension) without authentication?
    Thanks.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    No. Would this not possibly defeat/compromise the purpose of having some level of security? If you will provide some details about which endpoint, the logs, etc. Maybe some of us might be able to help.
