Manually Configure Yealink T58V
Discussion in '3CX Clients' started by 0xDEADC0DE, Nov 3, 2017.
  1. 0xDEADC0DE
    May 29, 2017
    11
    5
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @0xDEADC0DE
    As i understand you need 2 accounts on each phone? You can auto provision the first account and copy the settings you need to the second account. You can disable auto provisioning if you do need it from the phones webUI
