Mass recreate provisioning files
ezpc
Trainee Partner
I need to recreate all config files in order to specify a new IP.
What is the best way to do this?
(Already put "create a big button to recreate" on the suggestions!).
that suggestion is there a few times. i have had conversations with 3cx on this need.
if i recall, from the phone tab, selecting reprovision all phones will do the trick - but it will happen right then and there.
not good if you are deployed and it is the middle of the day.
Thanks, but, this won't work in this case :( Once I change the IP, the phones will no longer show up (physically shutting down the server, moving DC, then restarting).... I suppose I could do it at night just before the move, but it could screw up timings...
I guess easiest thing is to write a macro to go through all extensions and click ok... just a shame as a recreate button would work so well!
I don't want to reset pins as that will cause other problems...
If your phones are set up to re-provision on power-up, you could use the big button that supplies mains power to the PoE network switch ... Crude, but that would force your phones to look for provisioning!!!
Sorry if I didn't explain properly, I can easily get the phones to reprovision (I run a custom script along with curl that automatically goes through every phone and resets in a few seconds)... The issue is recreating the provisioning files on 3CX to contain new settings.
Maybe the DHCP Option 66 provisioning method would help here ...???
http://www.3cx.com/sip-phones/DHCP-option-66.html
best rgeards
Same question here. After editing the provisioning template I need to mass recreate the cfg files. My finger gets tired clicking OK...
3 years later any suggestions?
change daylight savings time checkbox on Settings->provisioning then set it back to previous setting. This recreates all config files.
(Depending on # of extensions and server specs it may take a bit of time.)
Nice hack! I will definitely try that out...
Getting Started - Admin
jaayb512
Get 3CX - Absolutely Free!
3CX
