Mass Update of Extensions
Discussion in '3CX Phone System - General' started by ntnetzeband, Jan 30, 2018.
  1. ntnetzeband
    Jul 30, 2016
    65
    5
    Anyone know of a way to mass update extensions? We used to configure the VLAN port through the provisioning template but since it is in the management console, we would like to utilize that.
  2. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    29
    You can control + click multiple extensions then click edit under the extension node to edit multiple extensions but unfortunately the VLAN setting is not a setting shows when doing this. :(
