Mating Microsoft Windows Fax Server with 3CX
Discussion in '3CX Phone System - General' started by TUser, Jul 6, 2011.
  1. TUser
    Jul 6, 2011
    Does anyone know where I could find information on how to get Microsoft Fax Services on Win2K8R2 to work with the 3CX Fax Server?
    I installed them both but I don't see where they actually work together. I am assuming that something should be listed under Devices in the MS Fax Manager but there's nothing there and I don't know how to add a device.
    Also, where is a good source for 3CX help. The system is fairly simple to use however the documentation and resources are bad unless you have to go out and hire a consultant. Not worth it for a simple issue.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    There is no integration. 3CX only supports inbound T38 Faxes.
  3. jtrollen
    May 17, 2010
    21
    I spent a lot of time trying to get this to work and I finally had success by using t38faxvoip (http://www.t38faxvoip.com). It essentially creates virtual sip modems that allow you to fax from the MS Fax server to the 3CX.
