Maximum DID numbers
Discussion in '3CX Phone System - General' started by htcomm, Aug 29, 2008.
  1. htcomm
    Jul 25, 2008
    17
    Does anyone know what the maximum number of DID numbers that can be added on a single SIP account on the 3CX ?
    I can add 21 numbers, but on the 22nd number, I get the following error:
    Cannot save Provider object: ERROR: value too long for type character varying(255)<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fGateway.php(289): safeExec(Object(PDOStatement), 'Cannot save Pro...')<br />
    #1 C:\Program Files\3CX PhoneSystem\Data\Http\gateway_lines_upd.php(405): fGateway::save(Object(oGateway))<br />
    #2 {main}
    I'm using 3CX 6.0.806.0 Free Version.
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    What I know 3CX is unlimted to register
