maximum number of calls to one phone
Discussion in '3CX Phone System - General' started by John Amey, Mar 30, 2017.
  1. John Amey
    Feb 15, 2017
    What is the maximum number of calls one phone can be receiving at one time. The customer is stating that sometimes calls go straight to VM. The customer has 6 trunks and the "I want to accept more than one call at the same time" status is checked for the receptionist. The receptionist is the only user in the main ring group. And the ring group is set to forward to the digital receptionist if there is no answer.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Keep in mind that "I want to accept more than one call at the same time" doesn't apply to a ring group. There's another setting for that (that 3cx prefers you don't change). Since the reception phone is the only member, I'd suggest pointing the incoming calls direct to the extension instead of a ring group.
  3. leejor
    11,086
    325
    How do you have the line keys, on the receptionist set set-up? Are they all the same extension number, or is each key a unique extension, but all in the one ring group?
