Maximum number of gateways
Discussion in '3CX Phone System - General' started by Keith, Aug 3, 2010.
  1. Keith
    Aug 3, 2010
    Does anyone know if there is a limit to the number of gateways, LinkSys SPA-3102 inparticular that can be connected to the 3CX system?
    Thanks in advance
    11,071
    323
    I don't believe that there is any limitation other than, perhaps a practical, limit. Were you thinking of adding hundreds, thousands?
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    The limits of 3CX are based on 2 things.
    1. Your call licence
    2. Your machine.
    3. Your network.
    All 3 things can be inproved, you can have as many PSTN devices/ voip providers or extensions connected. Having said that you can inmagine the enormity of netwrok traffic that can be generated when making a lot of calls, or those done by the re registration period of each device.
    Before you go on a PSTN buying spree, find out if there is a more pratical approach as to what you would like to achieve.
