MDL 1.4.7 compatible with current 3cX Build?(Ver 11, Build3)
Discussion in '3CX Phone System - General' started by SafeMart, Jan 30, 2013.
  1. SafeMart
    Jan 30, 2013
    I am using MDL's 1.4.7 version of their predictive dialer. Does anyone else use that? If so, are you using the current version of 3CX, Version 11 Build 3? Thanks!
  2. mdlsolutions
    Jul 7, 2009
    7
    Re: MDL 1.4.7 compatible with current 3cX Build?(Ver 11, Bui
    The MDLsolutions Predictive Dialer 1.4.7 was distributed before 3CX version 11 was available. At that time I believe 3CX version 9 was being used.
    You will need to upgrade to our Predictive Dialer version 2.65 or greater as that has been tested with 3CX version 11.
    Thank you,
    MDLsolutions
