media pass thru
Discussion in '3CX Phone System - General' started by tjabaut, Dec 19, 2007.
  1. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    One of the features listed with v5 is the so called media pass thru. How does one enable this. I assume that this would allow us to use the licenses to g729 built into most phones and gateway's correct?
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    I believe this is working pretty much like it was working on V3, even thoug then no one would call it that name. If you do not bind any extension or Voip provider to server media will pass through....
    Anyone correct me if im wrong...
    Cheers
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    309
    Its an automatic feature.
    Before, it would operate in two modes Direct or Bound
    Now, it can operate in 3 modes Direct, Proxy or Transcoding
    In Direct mode - all SIP and RTP traffic is between the phones, 3CX Phone System is not involved.
    In Proxy mode (or pass thru) - SIP traffic is signaled via 3CX phone system, but RTP traffic passes directly
    In Transcoding mode - all traffic is passed via 3CX Phone System.
    These modes are decided on by 3CX, but in anutshell
    Internal calls direct
    Calls between internal and external or between subnets are in proxy mode
    Calls are in transcoding mode if the phone does not support all features necessary for reliable operation
