Here are the logs: This is an inbound call with the media server running and one-way audio.
To: <sip:
[email protected]>;tag=973b4140
[email protected]>;tag=gK0857b7c6
Call-ID:
[email protected]
CSeq: 303725 ACK
Content-Length: 0
11/18/2016 12:12:51 PM - ConnCfmd from "KIDCHECK INC" <sip:
[email protected]>;tag=gK0857b7c6 to <sip:
11/18/2016 12:12:51 PM - Reported(Update): SE:12.2{Connected}
11/18/2016 12:12:51 PM - Issue: [Pres:310; act=Established;0;992]
11/18/2016 12:12:51 PM - StatusNotification: SE:12.2{Connected}; Skip=0
11/18/2016 12:12:51 PM - [CM503007]: Call(C:12): Extn:310 has joined, contact <sip:
[email protected]:5060>
11/18/2016 12:12:51 PM - onLegConnected
11/18/2016 12:12:51 PM - Reported(Update): SE:12.1{Connected}
11/18/2016 12:12:51 PM - Issue: [Pres:10000; act=Established;0;991]
11/18/2016 12:12:51 PM - StatusNotification: SE:12.1{Connected}; Skip=0
11/18/2016 12:12:51 PM - [CM503007]: Call(C:12): Line:10000<<+12085382000 has joined, contact <sip:
11/18/2016 12:12:51 PM - Call(C:12), Extn:310 on entry: DlgInfo(12-2321/Confirmed / R)
11/18/2016 12:12:51 PM - Notify dialog-info: Extn:310: sip:
[email protected]:5060, Call(C:12)
11/18/2016 12:12:51 PM - ~Target=RingAll800[Ext.310]
11/18/2016 12:12:51 PM - Session 2197 of leg L:12.1[Line:10000<<+12085382000] is connected
11/18/2016 12:12:51 PM - L:12.1[Line:10000<<+12085382000] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=39fc.a5e9bc931d255370f08cbf086d0c736c.0
[email protected]:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK39fc.a5e9bc931d255370f08cbf086d0c736c.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK39fc.f8d141b6a47e658bdec5d0da0f554eb5.1
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK39fc.c06399670fe86fbf1ba5bea9a44404e1.0
Via: SIP/2.0/UDP 74.120.93.198:5060;branch=z9hG4bK08B349aee9c4aa5746e
Record-Route: <sip:216.115.69.144;lr>
Record-Route: <sip:216.115.69.132;lr>
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 303725 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Content-Type: application/sdp
Supported: replaces
User-Agent: 3CXPhoneSystem 15.0.59950.0 (59299)
Content-Length: 298
v=0
o=3cxPS 50834964480 268250906625 IN IP4 208.185.166.70
s=3cxPS Audio call
c=IN IP4 208.185.166.70
t=0 0
m=audio 9000 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
11/18/2016 12:12:51 PM - Connected(UAS) from "KIDCHECK INC" <sip:
11/18/2016 12:12:51 PM - L:12.1[Line:10000<<+12085382000] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=39fc.a5e9bc931d255370f08cbf086d0c736c.0
[email protected]:
SIP/2.0 200 OK
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 303725 INVITE
Supported: replaces
Content-Length: 298
v=0
s=3cxPS Audio call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
11/18/2016 12:12:51 PM - SendMsg from <sip:
[email protected]>;tag=973b4140 to "KIDCHECK INC" <sip:
11/18/2016 12:12:51 PM - Set UAS contact sip:
[email protected]:5060 from: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:
[email protected]:5060]
11/18/2016 12:12:51 PM - L:12.1[Line:10000<<+12085382000]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
11/18/2016 12:12:51 PM - ~Route=Dev:sip:
11/18/2016 12:12:51 PM - L:12.2[Extn] has joined to L:12.1[Line:10000<<+12085382000]
11/18/2016 12:12:51 PM - Session 2200 of leg L:12.2[Extn] is connected
11/18/2016 12:12:51 PM - L:12.2[Extn] got Connected.UAC Recv 200/INVITE from 192.168.1.61:5060 tid=f41f716d0745811b Call-ID=KVhVvZ3iDBvnMgYGVxOQFg..:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.20:5060;branch=z9hG4bK-524287-1---f41f716d0745811b;rport=5060
Contact: <sip:
To: <sip:
[email protected]>;tag=757538714
[email protected]:5060;nf=e>;tag=74360d79
Call-ID: KVhVvZ3iDBvnMgYGVxOQFg..
CSeq: 1 INVITE
Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
User-Agent: Yealink SIP-T46G 28.80.0.130
Allow-Events: talk, hold, conference, refer, check-sync
Content-Length: 211
v=0
o=- 20271 20271 IN IP4 192.168.1.61
s=SDP data
c=IN IP4 192.168.1.61
t=0 0
m=audio 11800 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
a=sendrecv
11/18/2016 12:12:51 PM - Connected(UAC) from <sip:
[email protected]>;tag=757538714 to "KIDCHECK INC:Reception Step 1" <sip:
11/18/2016 12:12:51 PM - Remote SDP is set for leg L:12.2[Extn]
11/18/2016 12:12:51 PM - Answer SDP arrived on Leg L:12.2[Extn];
OnAnswer Recv 200/INVITE from 192.168.1.61:5060 tid=f41f716d0745811b Call-ID=KVhVvZ3iDBvnMgYGVxOQFg..:
SIP/2.0 200 OK
Contact: <sip:
To: <sip:
CSeq: 1 INVITE
Content-Length: 211
v=0
s=SDP data
t=0 0
a=ptime:20
a=fmtp:101 0-15
a=sendrecv
11/18/2016 12:12:51 PM - L:12.2[Extn] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=0175ac1ddc46794b Call-ID=KVhVvZ3iDBvnMgYGVxOQFg..:
ACK sip:
[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---0175ac1ddc46794b;rport
Max-Forwards: 70
Contact: <sip:
To: <sip:
CSeq: 1 ACK
Content-Length: 0
11/18/2016 12:12:51 PM - Call(C:12), Extn:310 on exit: DlgInfo(12-2321/Confirmed / R)
11/18/2016 12:12:51 PM - Call(C:12), Extn:310 on entry: DlgInfo(12-2321/Early / R)
11/18/2016 12:12:51 PM - SendMsg from "KIDCHECK INC:Reception Step 1" <sip:
[email protected]:5060;nf=e>;tag=74360d79 to <sip:
11/18/2016 12:12:44 PM - L:12.1[Line:10000<<+12085382000] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=39fc.a5e9bc931d255370f08cbf086d0c736c.0
[email protected]:
SIP/2.0 180 Ringing
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 303725 INVITE
Content-Length: 0
11/18/2016 12:12:44 PM - SendMsg from <sip:
11/18/2016 12:12:44 PM - Set UAS contact sip:
11/18/2016 12:12:44 PM - Provisional response arrived for session 2200 of Leg L:12.2[Extn]
11/18/2016 12:12:44 PM - L:12.2[Extn] got Provisional Recv 180/INVITE from 192.168.1.61:5060 tid=f41f716d0745811b Call-ID=KVhVvZ3iDBvnMgYGVxOQFg..:
SIP/2.0 180 Ringing
Contact: <sip:
To: <sip:
CSeq: 1 INVITE
Content-Length: 0
11/18/2016 12:12:44 PM - Provisional(180) from <sip:
11/18/2016 12:12:44 PM - [CM505001]: Endpoint Extn:310: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T46G 28.80.0.130] PBX contact: [sip:
11/18/2016 12:12:44 PM - [CM503002]: Call(C:12): Alerting Extn:310 by contact <sip:
11/18/2016 12:12:44 PM - Call(C:12), Extn:310 on exit: DlgInfo(12-2321/Early / R)
11/18/2016 12:12:44 PM - Call(C:12), Extn:310 on entry: DlgInfo(12-2321/Initial / R)
11/18/2016 12:12:44 PM - Notify dialog-info: Extn:310: sip:
11/18/2016 12:12:44 PM - Reported(Insert): SE:12.2{Ringing}
11/18/2016 12:12:44 PM - Issue: [Pres:310; act=Ringing;0;990]
11/18/2016 12:12:44 PM - StatusNotification: SE:12.2{Ringing}; Skip=0
11/18/2016 12:12:44 PM - UacSession 2200 has formed leg L:12.2[Extn]
11/18/2016 12:12:44 PM - Answer from <sip:
11/18/2016 12:12:44 PM - [CM503025]: Call(C:12): Calling T:RingAll:800@[Dev:sip:
[email protected]:5060] for L:12.1[Line:10000<<+12085382000]
11/18/2016 12:12:44 PM - Route to L:12.2[Extn] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=7e0bc5487e691451 Call-ID=KVhVvZ3iDBvnMgYGVxOQFg..:
INVITE sip:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---7e0bc5487e691451;rport
Max-Forwards: 70
Contact: <sip:
To: <sip:
[email protected]>
CSeq: 1 INVITE
Alert-Info: <http://www.notused.invalidtld>;info=external
Supported: replaces
Content-Length: 283
v=0
o=3cxPS 67159195648 178912231425 IN IP4 192.168.123.254
s=3cxPS Audio call
c=IN IP4 192.168.123.254
t=0 0
m=audio 7000 RTP/AVP 0 8 9 3 101
a=rtpmap:9 G722/8000
a=rtpmap:3 GSM/8000
a=sendrecv
11/18/2016 12:12:44 PM - Device (1241143785) is used in 1 calls: [12]
11/18/2016 12:12:44 PM - From ("KIDCHECK INC"<sip:
[email protected]:5060;nf=e>) is changed to "KIDCHECK INC:Reception Step 1"<sip:
11/18/2016 12:12:44 PM - Outbound URI is used: sip:
11/18/2016 12:12:44 PM - L:12.2[Extn]: SLA slot is acquired: 310#0 'idle'
11/18/2016 12:12:44 PM - SLA is not enabled for DN 310
11/18/2016 12:12:44 PM - SLA is globally disabled
11/18/2016 12:12:44 PM - Legs count: 2
11/18/2016 12:12:44 PM - Added leg L:12.2[Extn]
11/18/2016 12:12:44 PM - [Flow] Call(C:12): making call from L:12.1[Line:10000<<+12085382000] to T:RingAll:800@[Dev:sip:
11/18/2016 12:12:44 PM - [CM503027]: Call(C:12): From: Line:10000<<+12085382000 ("KIDCHECK INC" <sip:
[email protected]:5060>) to T:RingAll:800@[Dev:sip:
11/18/2016 12:12:44 PM - [CM503004]: Call(C:12): Route 1: from L:12.1[Line:10000<<+12085382000] to T:RingAll:800@[Dev:sip:
11/18/2016 12:12:44 PM - Busy check: Ext.310 is not busy
11/18/2016 12:12:44 PM - [Flow] Endpoint Extn:310 has no forwarding rule on reason 'All calls'
11/18/2016 12:12:44 PM - [Flow] Now does fit the rule, it is in-office time now
11/18/2016 12:12:44 PM - [Flow] Rule 4: week's day 5, start/stop secs: 30600/61200
11/18/2016 12:12:44 PM - [Flow] Rule 3: week's day 4, start/stop secs: 30600/61200
11/18/2016 12:12:44 PM - [Flow] Rule 2: week's day 3, start/stop secs: 30600/61200
11/18/2016 12:12:44 PM - [Flow] Rule 1: week's day 2, start/stop secs: 30600/61200
11/18/2016 12:12:44 PM - [Flow] Rule 0: week's day 1, start/stop secs: 30600/61200
11/18/2016 12:12:44 PM - [Flow] Now is 43964 seconds since midnight of 5th day of week
11/18/2016 12:12:44 PM - OverrideExt.310 has no profile override, RG calls are enabled
11/18/2016 12:12:44 PM - [Flow] Target endpoint for 310 is Extn:310
11/18/2016 12:12:44 PM - [Flow] Building target endpoint to 310 from "KIDCHECK INC:Reception Step 1" <sip:
11/18/2016 12:12:44 PM - [Flow] Call(C:12): has built target endpoint: RingAll:800 for call from L:12.1[Line:10000<<+12085382000]
11/18/2016 12:12:44 PM - [Flow] Target endpoint for 800 is RingAll:800
11/18/2016 12:12:44 PM - [Flow] Building target endpoint to 800 from "KIDCHECK INC" <sip:
11/18/2016 12:12:44 PM - [CM503010]: Call(C:12): Making route(s) from Line:10000<<+12085382000 to <sip:
11/18/2016 12:12:44 PM - SelectRouteReq
11/18/2016 12:12:44 PM - Remote SDP is set for leg L:12.1[Line:10000<<+12085382000]
11/18/2016 12:12:44 PM - OnOffer from "KIDCHECK INC"<sip:
11/18/2016 12:12:44 PM - [CM505003]: Provider:[Flowroute] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:
11/18/2016 12:12:44 PM - Reported(Insert): SE:12.1{Calling}
11/18/2016 12:12:44 PM - Issue: [Pres:10000; act=Alerting;0;989]
11/18/2016 12:12:44 PM - StatusNotification: SE:12.1{Calling}; Skip=0
11/18/2016 12:12:44 PM - Inbound DID: ''; Phonebook Name: ''
11/18/2016 12:12:44 PM - [CM500002]: Call(C:12): Info on incoming INVITE from Line:10000<<+12085382000:
Invite-IN Recv Req INVITE from 216.115.69.144:5060 tid=39fc.a5e9bc931d255370f08cbf086d0c736c.0
[email protected]:
INVITE sip:
Max-Forwards: 66
Contact: "KidCheck" <sip:
To: <sip:
[email protected]>
Call-ID:
[email protected]
CSeq: 303725 INVITE
Session-Expires: 1800
Min-SE: 90
P-Asserted-Identity: "KIDCHECK INC" <sip:
[email protected]>
Content-Length: 223
v=0
o=- 380662 198964 IN IP4 74.120.93.196
s=-
c=IN IP4 74.120.93.196
t=0 0
m=audio 12556 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
11/18/2016 12:12:44 PM - [CM503001]: Call(C:12): Incoming call from Line:10000<<+12085382000 to <sip:
11/18/2016 12:12:44 PM - Leg L:12.1[Line:10000<<+12085382000] has external party ID {+12085382000}
11/18/2016 12:12:44 PM - Line limit check: Current # of calls for line Lc:10000(@Flowroute[<sip:
[email protected]:5060>]) is 1; limit is 10
11/18/2016 12:12:44 PM - Device (1703244465) is used in 1 calls: [12]
11/18/2016 12:12:44 PM - Blacklist check: number '+12085382000', list: ''; result = false
11/18/2016 12:12:44 PM - Dev(1703244465):[sip:
[email protected]:5060 / 73742492]: PBX contact is resolved to public IP: <sip:
