Media Server Crash permanently
Discussion in '3CX Phone System - General' started by hamdiyigit, Mar 7, 2008.
  1. hamdiyigit
    Nov 7, 2007
    9
    11:52:36.703 Call::Terminate [CM503008]: Call(33): Call is terminated
    11:52:32.359 Call::Terminate [CM503008]: Call(30): Call is terminated
    11:52:20.390 CallLeg::eek:nConfirmed Session 476 of leg C:33.1 is confirmed
    11:52:20.296 CallCtrl::eek:nLegConnected [CM503007]: Call(33): Device joined: sip:10009@10.200.80.10:5060
    11:52:20.281 CallCtrl::eek:nLegConnected [CM503007]: Call(33): Device joined: sip:3805@10.200.80.52:5060
    11:52:20.281 MediaServerReporting::SetRemoteParty [MS210003] C:33.1:Answer provided. Connection(transcoding mode):10.200.80.40:7000(7001)
    11:52:20.281 MediaServerReporting::SetRemoteParty [MS210001] C:33.2:Answer received. RTP connection: 10.200.80.10:5016(5017)
    11:52:20.281 CallLeg::setRemoteSdp Remote SDP is set for legC:33.2
    11:52:18.062 Line::printEndpointInfo [CM505002]: Gateway:[Telekom] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NGAVFXO/6.09.0A.06.09Aug 30 2006] Transport: [sip:10.200.80.40:5060]
    11:52:18.062 CallCtrl::eek:nAnsweredCall [CM503002]: Call(33): Alerting sip:10009@10.200.80.10:5060
    11:52:16.875 MediaServerReporting::SetRemoteParty [MS210002] C:33.2:Offer provided. Connection(transcoding mode): 10.200.80.40:7002(7003)
    11:52:16.859 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(33): Calling: PSTNline:10009@[Dev:sip:10009@10.200.80.10:5060]
    11:52:16.859 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:905557087780@10.200.80.40]
    11:52:16.859 MediaServerReporting::SetRemoteParty [MS210000] C:33.1:Offer received. RTP connection: 10.200.80.52:16462(16463)
    11:52:16.843 CallLeg::setRemoteSdp Remote SDP is set for legC:33.1
    11:52:16.843 Extension::printEndpointInfo [CM505001]: Ext.3805: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/PAP2-3.1.22(LS)] Transport: [sip:10.200.80.40:5060]
    11:52:16.828 CallCtrl::eek:nIncomingCall [CM503001]: Call(33): Incoming call from Ext.3805 to [sip:905557087780@10.200.80.40]
    11:52:16.828 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:905557087780@10.200.80.40 SIP/2.0
    Via: SIP/2.0/UDP 10.200.80.52:5060;branch=z9hG4bK-3ff18ea4
    Max-Forwards: 70
    Contact: "3805"[sip:3805@10.200.80.52:5060]
    To: [sip:905557087780@10.200.80.40]
    From: "3805"[sip:3805@10.200.80.40];tag=8754dc6889ac708o0
    Call-ID: 9f230fe8-28362988@10.200.80.52
    CSeq: 102 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Proxy-Authorization: Digest username="3805",realm="3CXPhoneSystem",nonce="12849357136:e909194b24bdb896f8d18dad50cdd817",uri="sip:905557087780@10.200.80.40",algorithm=MD5,response="f79d1740efc87e2a7c6fd976ca548ab6"
    Supported: x-sipura, replaces
    User-Agent: Linksys/PAP2-3.1.22(LS)
    Content-Length: 0
    11:51:54.218 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10009 forwards to DN:8000
    11:51:54.218 Call::Terminate [CM503008]: Call(31): Call is terminated
    11:51:54.187 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10009 forwards to DN:8000
    11:51:54.171 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10009 forwards to DN:8000
    11:51:49.515 CallCtrl::eek:nLegConnected [CM503007]: Call(31): Device joined: sip:3838@10.200.80.116:5060
    11:51:49.515 Extension::printEndpointInfo [CM505001]: Ext.3838: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA962-5.2.2(SCb)] Transport: [sip:10.200.80.40:5060]
    11:51:49.515 CallCtrl::eek:nAnsweredCall [CM503002]: Call(31): Alerting sip:3838@10.200.80.116:5060
    11:51:49.500 Call::Terminate [CM503008]: Call(32): Call is terminated
    11:51:49.312 CallLeg::eek:nRefer Relpaces: 25da2370-a85a55fb@10.200.80.93;from-tag=9b34cec30c8daafo1;to-tag=3d4f4862
    11:51:49.312 CallLeg::eek:nRefer Refer: from=[sip:3804@10.200.80.40];tag=3cd97f5c469ac58di1; to="Telekom"[sip:10009@sipserver.bb.com.tr:5060];tag=1b235363; RefTo=[sip:3838@10.200.80.40?Replaces=25da2370-a85a55fb%4010.200.80.93%3Bfrom-tag%3D9b34cec30c8daafo1%3Bto-tag%3D3d4f4862]
    11:51:47.218 MediaServerConnected [CM112000] Media Server is connected
    11:51:47.218 ListenConnect SL: connected santral:0/MediaServer at [santral]/MediaServer
    11:51:47.187 ListenDisconnect SL: disconnected santral:0/MediaServer at [santral]/MediaServer
  2. hamdiyigit
    Nov 7, 2007
    9
    System event log message is : Faulting application 3CXMediaServer.exe, version 5.1.4128.0, faulting module 3CXMediaServer.exe, version 5.1.4128.0, fault address 0x0000e000.
    System: Win2003 R2
    Version : v.5.1.4128
    Ps. : If I use v.3.xxx , never crash my media server
  3. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Reaistall Windows and do a fresh install of 3CX
  4. hamdiyigit
    Nov 7, 2007
    9
    Hi ,
    If this operation absolutely solved my problem , ofcourse I can this ;)
    Are you sure ?
    Thank you,
    Hamdi Yigit
  5. igor.snezhko
    Jan 7, 2008
    668
    7
    I think this is more quick and robust solution than long time investigations of the authentification problems.
  6. hamdiyigit
    Nov 7, 2007
    9
    Hi ,
    I make format my system and reinstall OS , and install 3cx v.5
    But not change anything ...
    still .. Media server crash permanently..
    And now , I have return to v3..
  7. igor.snezhko
    Jan 7, 2008
    668
    7
    What other software are you using on same PC? DO you disable firewall?
  8. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    Maybe its related to the hardware you are using. Please post what VOIP provider or phones or VOIP gateway you are using... Also are you running a particular language version of Windows?
  9. hamdiyigit
    Nov 7, 2007
    9
    My system details :
    OS : Windows 2003 Server R2 English
    Gateway : Multitech Multivoip MVP210 (2 Analog Ports) and MVP410 (4 Analog ports)
    Phones : Linksys SPA922 , SPA962 , Linksys Pap2 ATA, 3CX Client Softphone
    There is no firewall enabled and not installed any other third party firewall software on my system.
    And there is no antivirus software installed on my system.
    I change my system hardware(I change ,CPU,mainboard,ram,hdd, even OS) and try again , but my problem is not solved.
    Win2003 server R2 English : Problem
    Win2003 Server R2 Turkish : Problem
    WinXp Pro English : Problem
    WinXP Pro Turkish : Problem
    When I use v3.xx , not any problem with Media Server ...
    Thank You,
    Hamdi Yigit
  10. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    There are settings in the configuration to check or uncheck that PBX delivers Audio as well in the extension side as in the provider side. Please play around with these settings and see what changes.
  11. hamdiyigit
    Nov 7, 2007
    9
    I change PBX delivers audio , check , uncheck and test again but is problem not solved.
    I see , incoming call process already transcoding mode on the v.5.xxx ; only extension to extension calls by-pass mode ;
    and when I stop 3cx phone system services on the server, all calls (extension to extension or extension to gateway or gateway to extension) terminated.
    But on the v.3.xx , when I stop 3cx phone system services on the server never terminate any calls.
