Mediant 2000 with 3CX
Discussion in '3CX Phone System - General' started by Keemat, Aug 16, 2007.
  1. Keemat
    Aug 16, 2007
    Please suggest is the Mediant 2000 will work with 3cx ..
    [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: 192.168.0.80 From: '1902'; To: '3700'; Rline: '3700'; Contact: '1902'
    Please suggest....
    Keemat
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    What is 3700 and what is 1902 in your phone configuration?
  3. Keemat
    Aug 16, 2007
    Mediant 2000 Config
    T1 ISDN Configuration
    Trunk ID Channels Phone Number
    4 24 1900
    3CX
    SIP Extension No : 3700
    Logs from Mediant 2000
    9d:14h:25m:57s ( lgr_stk_ses)(2834 ) ACK sip:3700@192.168.0.73;user=phone SIP/2.0 Via: SIP/2.0/UDP 192.168.0.80;branch=z9hG4bKacwAKQEdc From: <sip:1902@192.168.0.73>;tag=1c3593 To: <sip:3700@192.168.0.73>;tag=4c2d6c05 Call-ID: 90162227822278vkwe-1902--3700@192.168.0.80 CSeq: 7543812 ACK Max-Forwards: 70 User-Agent: Audiocodes-Sip-Gateway-Mediant 2000/v.4.20.354.559 Content-Length: 0
    9d:14h:25m:57s ( lgr_stk_mngr)(2835 ) DeleteSuspendEntryBusyTable-callid: 90162227822278vkwe-1902--3700@192.168.0.80 BusyEntry-ID: 0 Index: 0
    9d:14h:25m:57s ( lgr_flow)(2836 ) | | #0:RELEASE:(90162227822278vkwe-1902--3700@192.168.0.80)
    9d:14h:25m:57s ( lgr_aaa_mngr)(2837 ) |CALL_END |98 |0 |4 |3 |255 |1 |ISDN |TEL |192.168.0.80 |0.0.0.0 |0 |0 |1902 |2 |1 |3700 |3700 |0 |N/A |20 |0.0.0.0 |0 |IP |GWAPP_UNASSIGNED_NUMBER |0 |0 |0 |0 |90162227822278vkwe
    Keemat
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    Why 1902 is coming to 3CX? What rule is applied by your device to form this value?
    Sorry, I didn't use this device :oops:
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please seek help to your gateway's reseller, it may be better than seek for help over here.
    Good Luck .....
  6. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    If i understood well, thats a gateway. Go to your gateway configuration under "Manage gateways and Providers" click on that gateway and on the configurations go to the last tab and enable "User Ip in contacts to recognize source# and below input the gateway IP. It worked here for me, it might work for you too.
    Good Luck
