MediaServer - invalid socket (bug report)
Discussion in '3CX Phone System - General' started by onekit, Aug 17, 2007.
  1. onekit
    Aug 3, 2007
    27
    See on the time of log items generatings.
    Time to time I see such image in the "server status" menu.
    Problem solving - restart MediaServer service.
    But why it's happening?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    It is abnormal situation. Reasons are outside of PBX control. Additional information is required to find them.
    Regards
  3. onekit
    Aug 3, 2007
    27
    It happening not first time,
    if I will find how to get this error again, then I'll report about it. Keep in touch.
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    It will be interesting to catch this situation. If it happens "not first time" it will be easy to repeat.
    I hope you will provide logs for described situation. :)
