Mediatrix 1204 FXO
Discussion in '3CX Phone System - General' started by intercambio44, Nov 11, 2009.
  1. intercambio44
    Aug 22, 2008
    We try to get the Mediatrix FXO 4 port working with the newest 3CX version. Inbound is working fine, but we cannot do outbound calls. We saw some posts that users already did Outbound calls but we are not sure if they did this with the current version (8.0.9). The most posts over this gateway were two years old. Anybody can do Outbound calls with this gateway? Perhaps we can help you with config for inbound calls.
    Frank
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    If it still has two-stage dialing only - it is still unsupported.
  3. home
    Feb 25, 2009
    31
    Hi Frank
    We have been trying to get this device to work, without a great deal of success, I would be grateful if you would let me have a copy of your working config to date.
    Tim
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,888
    190
    You should use a supported device - much quicker and you will have much better results.
  5. Anhph68
    Jul 19, 2010
    @ admin: I have had a mediatrix 1204. And I try testing it with 3CX Phone System v9.
    I have tried quiet a long time, but lines of Mediatrix aren't accepted. Can you help me, please?
    Thank you so much!
  6. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    This is a Mediatrix issue, not a 3CX issue. The MEdiatrix does not work the same as the other supported gateways.
  7. intercambio44
    Aug 22, 2008
    Hello Anhph68,
    we have Mediatrix 1204 working with 3CX. Outbound and Inbound.
    Try this:
    On 3CX site:
    Add a PSTN device "generic" in 3CX. Do not set a password!!! Set in advanced "Require registration for" = "Do not require". All other setup are default. Port IDs for example 10001,10002,10003,10004.
    On Mediatrix 2104:
    Use the Mediatrix "Web Interface", much more easier as the MIB.
    1)Do in "Sip > Config" the IP of your 3CX Server in the SIP, Outbound and Presence Fields and set all port on 5060. Put in "SIP USER Config" the 4 port IDs of 3CX (ex. 10001,10002,10003,10004)
    2) Do in Sip > Authentication REALM: 3CXPHONESYSTEM (the word not the IP), put in user name for example 10001. And do not use a password!!!!!!
    3) Now take your "Unit Manager Network" Software and open with the "Unit Manager Client" the unit. You will find there Telefony Attributes set Port "Telephony Attributes" to "no restriction". "Automatic Call" to "Enable" and "Automatic call adress" to a phone numer or digital receptionist number or ring group. This number have to be the same as in inbound rule of this ID, for example 10001. For example: If you set here "Automatic call adress" to 100 and set up the gateway port 10001 in 3Cx "Configure where calls should be routed..." also to "Conect to extension" 100, the the extension 100 will ring!
    That is all, looks easy, but we spend a lot of hollidays and weekends to find out. Hope this will help you.
    Frank
  8. Anhph68
    Jul 19, 2010
    @intercambio:
    Thank you so much!
    sorry you, I was busy for a few days, so I can't reply your comment.
    I followed you instroductions. The status of lines of the Mediatrix 1204 is "registered", but when I connect port 1 of the Mediatrix 1204 to a fixed analog phone. There's nothing!
    Can you give me your email, please? I want to send you about some images of the configuration of my Mediatrix 1204. Maybe here (this forum) not upload images from my computer?
    I wait for your comment!
    Thanks a lot ^^
  9. Anhph68
    Jul 19, 2010
    This is my network
    I want to make a call from A to B and A to C
    and I want to ask you whether make a call from B to C or not.
    Thanks so much!
  10. intercambio44
    Aug 22, 2008
    you can send me emails to: frank@intercambio-bahia.com.br
    In your config I saw you try to conect a phone to 1204, this will not work because the Mediatrix 1204 is a FXO Gateway. You only can connect a PSTN line. What happend if you call a PSTN number?
    Send me as much information about your config on Mediatrix and on 3CX. Which firmeware do you use on Mediatrix?
    Regards Frank
