mediatrix 1204
Discussion in '3CX Phone System - General' started by jas1, Jun 8, 2007.
  1. jas1
    Jun 8, 2007
    HI does anyone one have any install notes/ setup notes on setting up a mediatrix 1204 to work with 3cx PBX has a PSTN gateway. :oops:
    Cant seem to get this working :(
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Unfortunatley that is not a supported device. It may be a bit of a challenge to configure and from what I understand it seems you will likely end up having to dedicate lines to out going / incomming ONLY.
    Hopefully someone might be able to shed light on this one. Be sure to go over the device's manual available online as well:
    http://www.mediatrix.com/support.php
