mediatrix 2102 not registered
Discussion in '3CX Phone System - General' started by gmwhite, Apr 10, 2010.
  1. gmwhite
    Apr 10, 2010
    I have a Mediatrix 2102 which I am attempting to connect to my 3cx, but it will not register. I would like to know if it is possible to do this before I spend a lot more time at this. I have successfully configured the PBX to my VoIP provider, added a couple of 3cx soft phones and an Aastra IP phone - all works well. I want to add my regular line to the PBX and have successfully configured a Linksys 3102 as a PSTN device; I want to use the Mediatrix as an ATA so that I can attach a couple of analogue phones, but can't get it to register.
    10,758
    286
    What does the 3CX log show when the device attempts to register. Or...does it even show an attempt? Depending on what you see, you may get a clue as to what is missing or datafilled incorrectly.
  3. gmwhite
    Apr 10, 2010
    The log has no record of any attempt to register. I don't know if there are more logs other than the "server" log accessed through the management console.
    I guess it should work, yet I have no error messages to guide me. Frustrating, but then I am new to this.
  4. leejor
    10,758
    286
    If there are no signs in the logs of any registration attempts then double check your settings in the 2102 devices. Either the messages are going to the wrong IP or the network settings are preventing messages from getting through. Are both the 3CX and ATA's are on the same network? Did you assign fixed IP's or using DHCP? Can you ping or log into the ATA's from a computer that you can also log into the 3CX PC? Does the mediatrix provide a syslog?
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,926
    241
    The Mediatrix gateways are not tested nor are they supported. You should use a supported gateway or ATA device with 3CX...
