mediatrix 4404
Discussion in '3CX Phone System - General' started by danielgc, Oct 16, 2007.
  1. danielgc
    Oct 16, 2007
    Does 3CX support this gateway? If so, is there any step-by-step guide i can follow? I can't get 3CX to work with this gateway. Any help will be appreciated.
    Thanxs.
    Daniel.
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    Hello
    Please send the detailed manual at 3cx@etyping.co.in so that we could guide you in a much better manner.
  3. danielgc
    Oct 16, 2007
    which manual are you talking about? the Mediatrix gateway manual?
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,005
    308
    We dont support that gateway. See our support section for the list of gateways that we do support.
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Nick,
    Just to confirmed that 3CX not support all Mediatrix gateways(FXO, BRI and PRI). Is it correct?
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I just signed up with a company to get those at reseller prices (plus other brands). The sales person there recommended those over some other ones. I won't be ordering that one to demo now.
    Glad someone asked about it.
  7. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    That's too bad they aren't supported. They are great gateways.
  8. voipx2004
    Apr 4, 2008
    I have the same problem, outgoing calls to ISDN line working, incoming calls log error "Authentication failed due to unidentified" and "Unidentified incoming call. Review INVITE and adjust source identification" .
    I need urgently Help, is my first installation of this product and Mediatrix 4404 works with Linksys products. INVITE is not in correct format...
    LOG:
    [CM302001]: Authorization system can not identify source of: SipReq: INVITE 10.10.1.105:5060 tid=a97907933 cseq=INVITE contact=NUMBDER_OUT@10.10.1.101:5061 / 451381171 from(wire)
    [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:10.10.1.105:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.10.1.101:5061;branch=z9hG4bKa97907933
    Route: [sip:10.10.1.105:5060;lr]
    Contact: [sip:NUMBER_OUT@10.10.1.101:5061]
    To: [sip:MSN1@10.10.1.105:5060]
    From: [sip:NUMBER_OUT@10.10.1.105:5060];tag=a46603cc4e60100
    Call-ID: 6b7e9558cdb3926d72d19d60ef9c7b8f@10.10.1.105
    CSeq: 451381171 INVITE
    Session-Expires: 3600
    Min-SE: 1800
    Allow: INVITE, ACK, BYE, CANCEL, REFER, NOTIFY
    Supported: timer, replaces
    User-Agent: Mediatrix 4404 v1.1.9.85
    Content-Length: 0
    [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 10.10.1.105:5060 tid=462a70cf5 cseq=INVITE contact=NUMBER_OUT@10.10.1.101:5061 / 451381172 from(wire)
    Via: SIP/2.0/UDP 10.10.1.101:5061;branch=z9hG4bK462a70cf5
    CSeq: 451381172 INVITE
    Min-SE: 1800
    Proxy-Authorization: Digest response="07794046999929a9438da2e37392f12c",username="10000",realm="3CXPhoneSystem",nonce="12851763760:12886bd4e1f5db3cbad7c667c9dde95f",algorithm=MD5,uri="sip:10.10.1.105:5060"
    Content-Length: 0
    [CM102001]: Authentication failed for SipReq: INVITE 10.10.1.105:5060 tid=462a70cf5 cseq=INVITE contact=NUMBER_OUT@10.10.1.101:5061 / 451381172 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
  9. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Try to set Source idetification for this gateway to
    Contact : host-port = Custom value 10.10.1.101:5061
  10. voipx2004
    Apr 4, 2008
    Very good!
    Problem is solved, many thanks! :D
    I have tried without port number during my tests...
    MEDIATRIX 4404 Works with direct MSN to internal numbers.
    Best regards.
  11. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Archie,
    Do you think the same fix would work with a Mediatrix 1204?
    I remember getting a very similiar error a while back but gave up trying to get it to work.
  12. archie
    3CX Support
    Aug 18, 2006
    1,299
    I'm not sure. We've tried to work with 1204 a long-long time ago and were unsuccessful. I recall we had a problem with one-stage dialing, but I don't remember details. After that fault we abandoned attempts to work with it.
