Mediatrix 4404
Discussion in '3CX Phone System - General' started by pedroramalho, Jan 28, 2008.
  1. pedroramalho
    Jan 28, 2008
    I'm try to connect one mediatrix 4404 but I can only made phone calls. When I try to recive one call the 3CX log say that are one problem authentication.
    Wath can I do?
    "Reason: Credentials don't matchm check that authorization-ID and pasword match the ones in extension settings"
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    please find the fileds somethibg like "authentication" in Mediatrix configuration and put the values of your lines. This might help
  3. voipx2004
    Apr 4, 2008
    I have the same problem, outgoing calls to ISDN line working, incoming calls log error "Authentication failed due to unidentified" and "Unidentified incoming call. Review INVITE and adjust source identification" .
    I need urgently Help, is my first installation of this product and Mediatrix 4404 works with Linksys products. INVITE is not in correct format...
    LOG:
    [CM302001]: Authorization system can not identify source of: SipReq: INVITE 10.10.1.105:5060 tid=a97907933 cseq=INVITE contact=NUMBDER_OUT@10.10.1.101:5061 / 451381171 from(wire)
    [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:10.10.1.105:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.10.1.101:5061;branch=z9hG4bKa97907933
    Route: [sip:10.10.1.105:5060;lr]
    Contact: [sip:NUMBER_OUT@10.10.1.101:5061]
    To: [sip:MSN1@10.10.1.105:5060]
    From: [sip:NUMBER_OUT@10.10.1.105:5060];tag=a46603cc4e60100
    Call-ID: 6b7e9558cdb3926d72d19d60ef9c7b8f@10.10.1.105
    CSeq: 451381171 INVITE
    Session-Expires: 3600
    Min-SE: 1800
    Allow: INVITE, ACK, BYE, CANCEL, REFER, NOTIFY
    Supported: timer, replaces
    User-Agent: Mediatrix 4404 v1.1.9.85
    Content-Length: 0
    [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 10.10.1.105:5060 tid=462a70cf5 cseq=INVITE contact=NUMBER_OUT@10.10.1.101:5061 / 451381172 from(wire)
    Via: SIP/2.0/UDP 10.10.1.101:5061;branch=z9hG4bK462a70cf5
    CSeq: 451381172 INVITE
    Min-SE: 1800
    Proxy-Authorization: Digest response="07794046999929a9438da2e37392f12c",username="10000",realm="3CXPhoneSystem",nonce="12851763760:12886bd4e1f5db3cbad7c667c9dde95f",algorithm=MD5,uri="sip:10.10.1.105:5060"
    Content-Length: 0
    [CM102001]: Authentication failed for SipReq: INVITE 10.10.1.105:5060 tid=462a70cf5 cseq=INVITE contact=NUMBER_OUT@10.10.1.101:5061 / 451381172 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
  4. pedroramalho
    Jan 28, 2008
    I have now see the problem
    you should change the header on the mediatrix with one rule.
    more information pedro.ramalho@lojavirtual.pt
