'Memory' Usage on Dashboard - Change
Discussion in 'Ideas' started by simonjh88, Aug 22, 2016.
  1. simonjh88
    Nov 17, 2015
    38
    As confirmed by the support team, the memory usage on the dashboard currently is a combination of physical RAM and Page Files.
    "The figure showing the Memory Usage also includes the Page Files allocated by the Windows OS, that is why you may see more Memory than that what you have in Physical RAM."
    It should either be just physical RAM or maybe have a separate value for pagefile. As pagefile is dynamic it seems a bit misleading to have it combined.
