Menu navigation #2
Discussion in 'Call Flow Designer' started by gustavskii, Aug 1, 2017.
  1. gustavskii
    Jan 26, 2016
    65
    Hello
    It is very confusing on how to navigate through menus in CFW
    There is a similar thread to this "Menu navigation". It only shows how to come back to previous menu using one loop, but what if you need to go back 2 steps
    So for example in my screenshot I need to go from "Option 3" in "Menu 2" to "Menu 1", and at the same time have "Option 2" in "Menu 2" go to "Menu 2"
    This is just an example, we have more complicated call flow right now with 3 levels of menus and user should be able to return to each level at any given time
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,684
    132
    Hi @gustavskii,
    Actually it's pretty simple. You just need a callflow variable for the condition to keep looping on each loop. For example, if you have 3 levels, you need these 3 variables:
    - ContinueLooping1 = true
    - ContinueLooping2 = true
    - ContinueLooping3 = true
    Then, you need to set the Condition property for each Loop, to each of these variables.
    Finally, in the branch where users selects where they want to go, you use Variable Assignment components to set these 3 variables to the proper value. For example, if you need to go to Loop1 you set:
    - ContinueLooping2 = false
    - ContinueLooping3 = false
    Or, if you need to go to Loop2, you set:
    Kind regards.
  3. gustavskii
    Jan 26, 2016
    65
    @edossantos thanks for reply, I`m a beginner in programming, so it is a bit confusing for me
    So in the screenshot above
    In the first loop, in loop expression I write:
    - ContinueLooping3 = true?
    or do I create it somewhere else
    I got this part:
    But how do I check if true then loop, if false then skip
    Do I write if statement, somehow, in the loop?
    When I put true in the loop it loops and when I put false in the loop it doesn`t
  4. edossantos
    Jun 27, 2007
    1,684
    132
    No, first, you need to define 3 callflow variables. In the Project Explorer, click the callflow name (for example Main.flow), then go to the Properties windows and click on the button on the right of "Variables". There define 3 variables:
    Like this:
    Then, for each Loop component, set the "Condition" property to the variable. For example:
    - For Loop1, Condition should be: callflow$.ContinueLooping1
    - For Loop2, Condition should be: callflow$.ContinueLooping2
    - For Loop3, Condition should be: callflow$.ContinueLooping3
    Hope it's more clear now.
    Regards.
    Ernesto.
