Menus in the PBX v.8
Discussion in '3CX Phone System - General' started by alloch70, Nov 5, 2009.
  1. alloch70
    Jul 8, 2009
    13
    After logging into the 3CX Phone System, if I expand the menus on the left side of the page, I can not collapse them. Any idea why this happens?
    Thanks,
    Allen
  2. fjkeith
    Sep 18, 2007
    49
    Ditto! I was just about to post on the same subject.
    3CX, is this a known issue?
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    Hi, need some info:
    - Which PBX version? (the one listed on login page)
    - You open it using Management Console application or in browser?
    - If in browser, in which one? (IE, Firefox, Opera)
    - If in browser, connection is remote or local?
    Regards
    vali
  4. alloch70
    Jul 8, 2009
    13
    Thank you for replying. I have resolved the issue by turning off the IE Enhanced Security Configuration in WS03. Do you know if there will be a version that will handle IEESC settings?
