Meridian System and 3CX
Discussion in '3CX Phone System - General' started by skeep, Dec 17, 2008.
  1. skeep
    Dec 16, 2008
    14
    Hi All,
    I have installed 3cx in a test bed and I have to say I am very impressed. So nice to have it on a windows system so I dont have to learn linux!!!!
    My question is can i integrate the 3CX with the current Meridian system we have installed and if so can i phone an extension from the 3cx to the meridian and visa versa? If so how to I go about this with a voip gateway?
  2. skeep
    Dec 16, 2008
    14
    ok so I think I can do this with a Patton SmartNode 4638.
    http://www.patton.com/products/pe_products.asp?category=329&tab=fb&MiDAS_SessionID=9e0dbee3f0734fd3a5c7bc8a91383e30
    Can anyone confirm this?
  3. Chris Martin
    Sep 22, 2007
    13
    If you check out the Add PSTN gateway node in the 3CX Management Console you will see that we have templated the configuration for Patton SmartNode 4634 and 4638 for specific firmwares mentioned in our http://www.3cx.com/voip-gateways/smartnode-isdn.html . If you're missing some templates, make sure you download the latest templates from the updates node. Please follow the config guide to the letter and ensure that you do not have a mismatch between the template chosen and the firmware in the Patton.
    Rgds,
    C.
