message before transfer
Discussion in '3CX Phone System - General' started by jantoney, Dec 17, 2007.
  1. jantoney
    Nov 20, 2007
    60
    Hey...
    I have a call group that rings when a call comes in from my PSTN lines.
    I then have a timeout of 30 seconds set and if no one answers then it transfers via a VOIP line to my mobile.
    I want to know if there is a way to play a message before the call is transfered to the external source?
    'EG thanks for calling. Please hold while we transfer you to one of our mobile technicians'
    I cant use a DR and just set the timeout to the length of the message because a DR cant transfer to an outside line.
    I also cant say press one to transfer to our mobile tech because of the same reason!
    (I will post a feature request for the DR > Outside line thing!)
    thanks in advanced
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    shure you can do.
    U can setup a DR with this message and after timeout 1 you connect then to a extension where a "Forward All Calls" is to your mobile.
    Or U can Add Call Queue with your Message in Intro prompt file and then after Ring Timeout (seconds) 1 or 0 you Destination if no answer << Forward to Outside Number
    where your mobile is.
    as always don´t forget outbound rules - if you use them for security when you have guests in your BPX
    Andy
  3. jantoney
    Nov 20, 2007
    60
    YAY
    Forward all calls.... mmmm why didn't i think of that!...
    thanks silentfun
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    no problem i thing there a many ways for each need we have and this forum is a perfect place to give an get help.
    Wish you a merry x-mas
    Andy
