Message in ACTIVITY log - PBX has dropped a message
Discussion in '3CX Phone System - General' started by cmdias, Mar 6, 2017.
  1. cmdias
    Feb 13, 2017
    31
    Hi guys,
    in my activity log i get many lines like te folowing: (3cx v15)
    03/06/2017 10:03:35 AM - PBX has dropped a message with 'User-Agent: voip.ms' from IP xxx.xxx.xxx.xxx because it is on blocked UAs list
    xxx.xxx.xxx.xxx = ip of my trunk provider from voip.ms
    the ip adress in question is WHITELISTED in 3cx....
    should i worry about this ? ... i'm investigation a radom drop for incoming calls.....
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    Hello @cmdias
    Please note that the word voip is commonly used in known hacking tools and 3CX ignores invites that contains the word voip in the user agent field.
    Please note that in SP5 released friday this has been fixed so make sure you upgrade to SP5 and provide us with a feedback
  3. cmdias
    Feb 13, 2017
    31
    great... will do the update today!!!!
    but is this an informative info only or is 3cx really blocking something??
  4. cmdias
    Feb 13, 2017
    31
    in most of my settings i use the IP directly...
  5. cmdias
    Feb 13, 2017
    31
    example in the log bellow the two first lines look like LEGIT blocks.... but the rest are the IP from my wite list!!!
    03/06/2017 10:11:26 AM - PBX has dropped a message with 'User-Agent: sipcli/v1.8' from IP 104.198.95.236 because it is on blocked UAs list
    03/06/2017 10:10:36 AM - PBX has dropped a message with 'User-Agent: sipcli/v1.8' from IP 163.172.77.148 because it is on blocked UAs list
    03/06/2017 10:03:35 AM - PBX has dropped a message with 'User-Agent: voip.ms' from IP 67.205.74.xxx because it is on blocked UAs list
    03/06/2017 10:03:30 AM - PBX has dropped a message with 'User-Agent: voip.ms' from IP 67.205.74.xxx because it is on blocked UAs list
    03/06/2017 10:03:28 AM - PBX has dropped a message with 'User-Agent: voip.ms' from IP 67.205.74.xxx because it is on blocked UAs list
    03/06/2017 10:03:27 AM - PBX has dropped a message with 'User-Agent: voip.ms' from IP 67.205.74.xxx because it is on blocked UAs list
  6. cmdias
    Feb 13, 2017
    31
    but thx for the info!!! updating ASAP!
