Message Indicator Support
Discussion in '3CX Phone System - General' started by dekatech, Feb 13, 2007.
  1. dekatech
    Feb 13, 2007
    82
    Noticed one topic with no reply. Are there any plans for message indicator support for any phone? IP 501 or the Cisco phones?
    Travis
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    At the moment there are no plans for indicator directly on the phone. Possibly be included in feature builds as part of the call assistant.
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    To make it more clear: we're going to support standard (as in RFC 3842) scheme of indicating of waiting messages, but this task has low priority right now. But this feature will appear for sure. You may expect it to be available in a month or two. I cannot tell more exact dates.
  4. dekatech
    Feb 13, 2007
    82
    Thanks for the response
    Wanted to say thanks for the response. It was the answer I was hoping for.
    Travis
