Message Saving Failed (On PSTN calls SPA3102) (resolved)
Discussion in '3CX Phone System - General' started by FGCUHank, Feb 27, 2010.
  1. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    I'm a new 3CX convert, now currently dumping 2 asterisk now and 2 asterisk business editions at home and three of my sites. Setup was a no brainer.
    Side question before I get into my question. Is Nick Galea the same Nick from GFI and 2x? I love and still have those products at customer sites.
    I have a spa3102 and inbound/outbound calls are working from the pots line.
    I'm waiting for a DID from my voip provider to see if this condition exists on voip trunks as well.
    On inbound calls from the POTS through the spa I receive a message saving failed when trying to leave a message.
    However on internal calls, extension to extension, message saving works.
    Any ideas would be greatly appreciated.
    Hank
    Sorry for the bad log posting.
    Time Message
    00:04:10.140
    [CM503008]: Call(107): Call is terminated
    00:03:53.233
    [CM503007]: Call(107): Device joined: sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    00:03:53.233
    [CM503007]: Call(107): Device joined: sip:10001@192.168.3.7:5062
    00:03:53.218
    [CM505001]: Ext.99: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:99@127.0.0.1:5060]
    00:03:53.218
    [CM503002]: Call(107): Alerting sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    00:03:53.108
    [CM503003]: Call(107): Call to sip:10@192.168.3.4 has failed; Cause: 487 Request Terminated; from IP:192.168.3.7:5060
    00:03:53.061
    [CM503025]: Call(107): Calling Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    00:03:53.046
    [CM503005]: Call(107): Forwarding: Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    00:03:44.843
    Active calls counted toward license limit: [107]
    00:03:23.077
    [CM505001]: Ext.10: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:10@192.168.3.4:5060]
    00:03:23.077
    [CM503002]: Call(107): Alerting sip:10@192.168.3.7:5060
    00:03:22.999
    [CM503025]: Call(107): Calling Ext:Ext.10@[Dev:sip:10@192.168.3.7:5060]
    00:03:22.968
    [CM503004]: Call(107): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.3.7:5060]
    00:03:22.968
    [CM503010]: Making route(s) to <sip:10@192.168.3.4:5060>
    00:03:22.952
    [CM505002]: Gateway:[SPA-3102] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:10001@192.168.3.4:5060]
    00:03:22.936
    [CM503001]: Call(107): Incoming call from *10001@(Ln.10001@SPA-3102) to <sip:10@192.168.3.4:5060>
    00:03:22.936
    [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:10
    00:03:12.843
    Active calls counted toward license limit: []
    00:02:40.843
    00:02:08.843
    00:01:44.296
    [CM503008]: Call(106): Call is terminated
    00:01:36.843
    Active calls counted toward license limit: [106]
    00:01:25.640
    [CM503007]: Call(106): Device joined: sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    00:01:25.624
    [CM503007]: Call(106): Device joined: sip:10001@192.168.3.7:5062
    00:01:25.624
    00:01:25.624
    [CM503002]: Call(106): Alerting sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    00:01:25.608
    [CM503003]: Call(106): Call to sip:10@192.168.3.4 has failed; Cause: 487 Request Terminated; from IP:192.168.3.7:5060
    00:01:25.265
    [CM503025]: Call(106): Calling Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    00:01:25.249
    [CM503005]: Call(106): Forwarding: Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    00:01:04.843
    00:00:55.530
    00:00:55.530
    [CM503002]: Call(106): Alerting sip:10@192.168.3.7:5060
    00:00:55.249
    [CM503025]: Call(106): Calling Ext:Ext.10@[Dev:sip:10@192.168.3.7:5060]
    00:00:55.202
    [CM503004]: Call(106): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.3.7:5060]
    00:00:55.202
    00:00:55.202
    00:00:55.186
    [CM503001]: Call(106): Incoming call from *10001@(Ln.10001@SPA-3102) to <sip:10@192.168.3.4:5060>
    00:00:55.186
    00:00:32.843
    2010/02/27 >>00:00:00.843
    23:59:28.843
    23:58:56.843
    23:58:24.843
    23:57:52.843
    23:57:28.952
    [CM503008]: Call(105): Call is terminated
    23:57:20.843
    Active calls counted toward license limit: [105]
    23:57:13.061
    [CM503007]: Call(105): Device joined: sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    23:57:13.061
    [CM503007]: Call(105): Device joined: sip:14@192.168.3.109:5060
    23:57:13.046
    23:57:13.046
    [CM503002]: Call(105): Alerting sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    23:57:12.936
    [CM503003]: Call(105): Call to sip:10@192.168.3.4 has failed; Cause: 487 Request Terminated; from IP:192.168.3.7:5060
    23:57:12.921
    [CM503025]: Call(105): Calling Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    23:57:12.905
    [CM503005]: Call(105): Forwarding: Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    23:56:48.843
    23:56:42.983
    23:56:42.983
    [CM503002]: Call(105): Alerting sip:10@192.168.3.7:5060
    23:56:42.858
    [CM503025]: Call(105): Calling Ext:Ext.10@[Dev:sip:10@192.168.3.7:5060]
    23:56:42.827
    [CM503004]: Call(105): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.3.7:5060]
    23:56:42.827
    [CM503010]: Making route(s) to <sip:10@192.168.3.4;user=phone>
    23:56:42.811
    [CM505001]: Ext.14: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_550-UA/2.2.2.0084] PBX contact: [sip:14@192.168.3.4:5060]
    23:56:42.796
    [CM503001]: Call(105): Incoming call from Ext.14 to <sip:10@192.168.3.4;user=phone>
    23:56:26.124
    [CM306003]: SIP IP:port mapping (71.54.11.98:1024) resolved by STUN server 94.228.101.70:3478 differs from the one (71.54.11.98:5060 resolved by STUN server 193.200.249.2
    23:56:26.108
    [CM306003]: SIP IP:port mapping (71.54.11.98:5060) resolved by STUN server 94.228.101.70:3478 differs from the one (71.54.11.98:1024 resolved by STUN server 193.200.249.2
    23:56:25.577
    [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 94.228.101.70:3478 over Transport 192.168.3.1:5060
    23:56:25.577
    [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 94.228.101.70:3478 over Transport 192.168.3.4:5060
    23:56:16.843
    23:55:44.843
    23:55:12.843
    23:54:40.843
    23:54:08.843
    23:53:39.124
    [CM503008]: Call(104): Call is terminated
    23:53:36.843
    Active calls counted toward license limit: [104]
    23:53:22.593
    [CM503007]: Call(104): Device joined: sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    23:53:22.593
    [CM503007]: Call(104): Device joined: sip:10001@192.168.3.7:5062
    23:53:22.577
    23:53:22.577
    [CM503002]: Call(104): Alerting sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    23:53:22.421
    [CM503025]: Call(104): Calling Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    23:53:22.374
    [CM503004]: Call(104): Route 1: Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    23:53:22.374
    [CM503010]: Making route(s) to <sip:14@192.168.3.4:5060;user=vmail>
    23:53:22.374
    23:53:22.358
    [CM503001]: Call(104): Incoming call from *10001@(Ln.10001@SPA-3102) to <sip:14@192.168.3.4:5060;user=vmail>
    23:53:22.358
    [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to VM:14
    23:53:04.843
    23:53:01.671
    [CM503008]: Call(103): Call is terminated
    23:52:59.765
    [CM503007]: Call(103): Device joined: sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    23:52:59.765
    [CM503007]: Call(103): Device joined: sip:10001@192.168.3.7:5062
    23:52:59.749
    23:52:59.749
    [CM503002]: Call(103): Alerting sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    23:52:59.593
    [CM503025]: Call(103): Calling Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    23:52:59.561
    [CM503004]: Call(103): Route 1: Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    23:52:59.561
    23:52:59.561
    23:52:59.546
    [CM503001]: Call(103): Incoming call from *10001@(Ln.10001@SPA-3102) to <sip:14@192.168.3.4:5060;user=vmail>
    23:52:59.546
    23:52:32.843
    23:52:25.311
    [CM503008]: Call(102): Call is terminated
    23:52:08.218
    [CM503007]: Call(102): Device joined: sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    23:52:08.218
    [CM503007]: Call(102): Device joined: sip:10001@192.168.3.7:5062
    23:52:08.202
    00:02:08.843
    00:01:36.843
    00:01:25.624
    00:01:25.624
    00:01:25.265
    00:01:04.843
    00:00:55.530
    00:00:55.202
    00:00:55.202
    00:00:55.186
    23:58:56.843
    23:57:52.843
    23:57:20.843
    23:57:13.061
    23:57:13.046
    23:57:12.921
    23:56:48.843
    23:56:42.983
    23:56:42.827
    23:56:42.811
    23:56:26.124
    23:56:25.577
    23:56:16.843
    23:55:12.843
    23:54:08.843
    23:53:36.843
    23:53:22.593
    23:53:22.577
    23:53:22.374
    23:53:22.374
    23:53:22.358
    23:53:01.671
    23:52:59.765
    23:52:59.749
    23:52:59.561
    23:52:59.561
    23:52:59.546
    23:52:25.311
    23:52:08.218
    23:52:08.202
    [CM503002]: Call(102): Alerting sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c
    23:52:08.015
    [CM503004]: Call(102): Route 1: Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=db0c86121700d89c]
    23:52:08.015
    23:52:07.983
    [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to VM:10
    23:51:30.827
    23:50:26.827
    23:49:22.827
    23:48:18.827
    23:47:14.827
    23:46:42.827
  2. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Re: Message Saving Failed (On PSTN calls)
    I wanted to post back that message saving works on my 2 voipvoip trunks. Just not from spa3102
  3. leejor
    10,732
    277
    Go back over all of the settings in the 3102. Does the call drop when answered by an extension rather than the VM?
  4. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Thanks for your reply.
    That is the interesting point. Calls coming in on the pstn are just fine. They can be picked up by any extension or ring group. For the moment I have it pointed to go to the voip extension on the spa3102 as it has an old cordless phone with an answering machine attached.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi Hank,
    http://www.3cx.com/forums/no-incoming-line-on-linksys-spa-13244.html#p68323
    There are description and comments/solution for very similar problem.
    There was "<" prepended, in your case it is "*"
    Is it the same problem?
  6. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    That is what's strange. Inbound and outbound calls through the SPA3102 are fine.
    Only when I go to leave a message via an inbound call through the SPA3102 do I get the Message Saving Failed error.
    Calling extension to extension and leaving a vm works.
    Calling in on a voip trunk and leaving a message works.
    Unless anyone has any other ideas I may do a factory reset on the spa, deleted it from 3cx and try again.
  7. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Thanks to Sy for catching the "*" in the logs.
    Without a factory reset, I went thought the SPA3102 setup again and using the doc at http: //www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE
    In step 22 "In the PSTN-To_Voip Gateway Setup secton"
    see step e: Set the PSTN Caller ID Pattern field to "*" Note that in some geographical areas, this may cause incoming calls to fail, because the device incorrectly interprets the caller id format. If this is the case, you may need to disable callerid parsing by setting this field to empty.
    Well, my inbound and outbound calls worked but this was the only "*" I added to the config. So thus I removed it and voicemail from the spa3102 now works.
    In a side note on the above doc, step 13, I set line 1 to yes and configured an extension for my wife's favorite analog cordless phone. It works fine.
    Thanks again for all the help.
  8. leejor
    10,732
    277
    That simple little * has caused a number of problems. And, yes, the FXS port can be used along with the FXO port.
