Message Waiting Indicator does not work
Discussion in '3CX Phone System - General' started by EddyHahn, Sep 27, 2007.
  1. EddyHahn
    Sep 27, 2007
    5
    I have a registered small business server version ( i had upgraded from the free version by entering the license code). The message waiting indicator does not work on my Polycom 301,501 or 320 phones. I have restarted all the services still no luck.
    Any idea how to fix it?
    Thanks,
    Eddy
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please try:
    Logon the phone web admin > Lines >Line1>Message Center
    Subscriber: your EXT
    Callback Mode: Contact
    Callback Contact: 999 (3CX default VM access number)
    If using FTP, HTTP and etc to download the cfg file:
    mwi msg.mwi.1.subscribe="your EXT"
    msg.mwi.1.callBackMode="contact"
    msg.mwi.1.callBack="999"
  3. EddyHahn
    Sep 27, 2007
    5
    Thanks!
    Worked great!
    Eddy
